Question about Mitsubishi WS-65908 TV
Mitsubishi WS-65908 Error Code 24
Hello all
I am hoping to get some help with my problem.
Set stats:
Mitsubishi WS-65908
serial 109029
Feb '02
Error Code 24
So here is the deal - I push the power button, I get the usual 'click' followed by the usual high voltage crackle, then 'click' it shuts off..
I have checked pico fuses (F9A04 and F9A05), 3.9 Ohm feedback resistors (R8C05, R8C06, R8C13, R8C14, R8C21, R8C22, R8C29, R8C30, R8C37, R8C38, R8C45, and R8C46), and 150 Ohm resistors (R8C07, R8C15, R8C23, R8C31, R8C39, and R8C47) and they all seem fine.
I am about to change the convergence ICs, but I was hoping to get a second opinion first.
Any thoughts?
  • 116 Answers
If you have an ohm meter, check the resistance from F9A04 to ground, and then reverse the leads and check F9A05 to ground. These supply +24 and -24 to the convergence integrated circuits. The conv ic's may be bad. Also, code 24 usually indicates vertical deflection failure as well. One other check to make.....The pic tubes on this set may leak a few drops of coolant onto the boards. Look VERY carefully for liquid drops on the boards or a green and or white corrosion spot or two on the boards under the pic tubes-near the front of the chassis.
Posted on Apr 16, 2009
Need a power board #930b867001
not available for a long time---does the set show any error when the self check is tried?
Dec 16, 2012 | Mitsubishi WS-65908 TV
No red on mitsubishi ws-65908
DTV is HD input but look to see if red lens is lit====set does have a hard reset which might cure it if it is a issue---it is based at the exact model number, a four digit code and the working Mitsubishi remote control.
Aug 26, 2012 | Mitsubishi WS-65908 TV
How do I reset my Mitsubishi WS-65908
Model number here has 3 hidden menus--adjustment (keep out of that one) and convergence, and OPTION menu.
In the Option menu with the Mitsubishi remote you can do a hard reset of entire set--sets everything back to factory except convergence adjustments.
This requires the Mitsubishi remote and a 4 digit number code.
I am willing to give that but first would like to know WHY you wish to do that as it will not cure all problems like dead set, convergence etc.
Apr 16, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
The Mitsubishi Diamond Series WS-65908 does not power up. The troubleshooting code is 2-4
1blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
If it is 2,4 you have a problem in the vertical circuit and I would suggest you first look for any signs of glycol there.
Let me know if you need more information.
Oct 01, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I have a WS has the same problum--listed on this site.......power on for 3 seconds...and it said this.... Do the self test this model has: When set shuts off and on front of set power...
Error code 23 on this set means that the Horizontal Deflection circuit of the set has failed. Usually this points to a damaged Horizontal Deflection IC and sometimes the HOT(Horiziontal Output Transistor) as well, not to mention the resistors that are blown when the IC failed. Replacing these parts should resolve the problem.
PS:Note that the Deflection circuit involves certain high-voltage components and prior to repair it is advisable to discharge the high voltage before attempting the repair. You will also need to know how to use a multimeter(to test the HOT and look for blown resistors) and a soldering gun. If you think you can do it yourself, let me know and I will provide you detailed step by step instructions.
Sep 15, 2011 | Mitsubishi WS-65908 TV
Power on for 3 seconds then shuts off
When set shuts off and on front of set power light goes out:
Press and hold on the front of the set both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks a pause and then repeats it several times.
This feature will narrow down where the problem is.
Let me know what error code is found and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Sep 29, 2010 | Mitsubishi WS-65908 TV
I have a mitsubishi ws 65807, i get trouble code 23
The problem is most likely convergence integrated circuit failure. I recommend finding a local Mitsubishi repair center.
Dec 05, 2008 | Mitsubishi WS-65908 TV
Convergence issue on Mitsubishi
Check your error codes first and see what error it's given. If done right it would last. see for how to do error codes
Jan 06, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-65908 TV Logo
460 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
