Question about Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD
Crosshairs are cocked to the right.
This is a Tasco World Class 3X-9X.40 Riflescope. The crosshairs are cocked to the right instead of being horizontal and perpendicular. It has given excellent service up until now. Is there a way to line the crosshairs up properly? Thank you, Rhett Sanders
  • rs5775 Dec 15, 2008
    Thanks. The scope is in the rings correctly. Even with scope out of the rings when you hold the adjustment knobs in the correct position, the crosshairs are still cocked to the right -- like the crosshairs in the scope itself have shifter almost to this position -- X instead of + -- any ideas about that?
  • rs5775 Dec 31, 2008
    The problem is INSIDE the scope. Turning the scope in the scope rings does not solve this problem. When the cross hairs are verticle and horizontal the adjustment knobs are "****-sided" (like 10 and 1 o'clock on a clock instead of 12 and 3 o'clock...) Is there any way to correct that? RS
    Problem Solver:
  • 5 Answers
1. You first make a 'plumb line' to compare your cross hairs to. Go out about 15 - 25 meters and hand a length of para-cord or reasonably thick string (so you can find it easily in the scope), weight the end of the cord will some lead weights. I've even used some box end wrenches tied to the end in the field.
2. Fill a small ice-cream pale or similar with a couple liters of engine oil that the weights on your line with hang in. The oil will eliminate the line from swaying by dragging on the weights and ensuring verticality
3. Place the rifle in a secure mount and re-enforce with some sandbags.
4. Line up the scope (mounted on the rifle) with the line.
5. Use a small level to ensure the rifle is as close to perfectly level as you can make it, both front to back and side to side.
6. Loosen the scope in the rings and adjust the scope untill the cross hairs are vertically in-line with your plumb line.
7. When you are satisfied tighten the scope down and use some medium stength (blue) locktight on the screws. Use the manufacturer's suggested tourque spec and Avoid Over Tourqueing the screws. Some specs are as little as 10 - 20 INCH pounds. Thats around one to one and a half FOOT pounds
It takes some time and a little prep work - but if done with some care it can yield fine results. Remember to use caution when tourquing the screws - people often confuse INCH punds and FOOT pounds. the conversion is 12 Inch pounds to 1 Foot pound.
If you can't get a proper tourque wrench you are better off using a little less tourque and utilize some Lock Tite to make sure the screws wont move down the road.
Posted on Dec 30, 2008
    Problem Solver:
  • 16 Answers
Your scope has spun in the scope rings. Loosen the screws holding the scope to the rifle and turn scope until crosshairs are into position. Then tighten screws. You will need to sight in again. If it keeps moving replace scope rings.
Posted on Dec 15, 2008
I want to register my riflescope
Go to the tasco web site or mail the registration in.
Nov 13, 2014 | Tasco 3-9x40 World Class Riflescope 30/30...
The crosshairs broke
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Jul 20, 2012 | Bushnell 3-9x40 Mattee R/g Crosshairs...
I have tasco #62TR rifle scope. I has stadia crosshairs and an adjustable top turret with various ranges for elk, deer, and antelope. However I cannot find any paperwork describing these features, and I...
Sight in rifle and put the on top turret with zero facing back.do not let knob"click".Aim at animal and adjust power(3-9etc)until body is bracketed by both crosshairs.Look in little window in eyepiece for type of animal.Click top turret to proper yardage(200,300etc).This allows for bullet drop.I've had one on a .270 for 30 yrs and never used this feature.
Dec 05, 2010 | Tasco 3-9x Variable Riflescope
My 3x-9x.40 scope shoots low and to the right,what does one click on elevation and wind represent?
Most scopes of this type move the bullet impact 1/4 inch at 100 yards, or 1/4 minute of angle.
Sep 19, 2010 | Tasco 3-9x40 World Class Riflescope 30/30...
Point of impact changes with every shot
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Jul 30, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
A piece of lint has fallen across the crosshairs on the left side
Have you tried either a throttled down vacuum or a can of air (spray)?
Mar 27, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD Logo
473 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Piyal Perera
Piyal Perera
Are you a Tasco Optic Expert? Answer questions, earn points and help others
