Question about Kenmore Heating & Cooling
Thru wall AC not turning on. 580.76081700
Power running to unit. Not turning on. What can I do to troubleshoot? Thank you.
  • jason_pascua Dec 12, 2008
    The entire system doesn't turn on. The reset button light is on but not the AC itself. I tested the wire and the wire is good.
  • Ken Bledsoe May 11, 2010
    Can you turn on the fan at least?
  • 398 Answers
SOURCE: Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Posted on Mar 18, 2009
  • 12 Answers
SOURCE: I have a thru the wall fedders ac unit. The heat
no blower !!! or heating element is bad or switch try putting the fan on only if it works than it is probaly the switch not letting the blower on only heat
Posted on Apr 01, 2009
  • 659 Answers
SOURCE: heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
  • 4 Answers
SOURCE: I have an Amana PBE12 Thru-Wall AC/Heater for my
is the breaker large enough for the unit? this could be the compressor locking up if if it a heat pump style, or sticking thermostat..
Posted on Jan 18, 2010
heatman101
  • 43501 Answers
SOURCE: Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Posted on Jul 21, 2010
Testimonial: "Thanks for the speedy reply and your time."
With a Kenmore 8000 BTU ac window unit there is a green wire that runs from underneath the control panel. Where does that go?
Most of the time a green wire is a ground and should be attached to the metal frame using a existing screw or a self tapping sheet metal screw. Thank you.
Aug 26, 2011 | Kenmore 75080 Thru-Wall/Window Air...
AF-S80MX Thru-Wall/Window Air Conditioner: What kind of refrigerant does this unit uses? ...
Most new window units are using R-22 or it's most common alternative R-410A - but you will need to check the 'data tag' on the AC to be sure. All AC units have a data tag (either metal or paper label) - somewhere on the AC - which gives you model number, size, voltage, and type of Refrigerant, as well as other info.
good luck!
May 08, 2010 | Sharp AF-S80MX Thru-Wall/Window Air...
Wall ac will not turn off
Yes it sounds to me like you have found the problem and I do recommend www.appliance411.com. They may not have the part you're looking for on the site but they might be able to link you to the most inexpensive parts available with the exception of used parts. Hope this helps, good luck!
Sep 02, 2009 | Carrier XCB121E Air Conditioner
Amana thru the wall ac unit won't turn off
The adjustment knob on the unit does not turn down how do you get the knobs off? Can we replace the control unit with one that is touch control? Could the problem of it not turning down be the thermostat? It is an Amana PTC153A35AD wall unit.
Jul 02, 2009 | Heating & Cooling
Heat doesn't work on ac
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Help
go to sharpusa.com and click on support, they have all the model airconditioners and all the help. its in pdf format and i dont know how to paste the info. really easy problem to fix.
Basically, tells you to make sure air filter is clean.Unplug from wall, then hold Power/on/off button down and plug unit in wall. press Power/on/off button until you hear a beeping sound(approx 5 sec) then disconnect powerplug from wall. plug back in and start your ac again. it should work!
If this dont work try the same thing but by pressing the Mode button and same kind of operation as above, but the unit will start to operate after you press mode and herar the beeps. turn off by pressing On/off button. then start as normal. if you cant get it go visit the website.
Jul 16, 2008 | Sharp ENERGY STAR AF-S60FX...
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Fedders Window AC Unit
I would try to start the unit with only the fan running at first. If it stays running then cycle on the compressor and see how it does. If the unit does not operate when compressor is turne on then we have to dig deeper into that.
Aug 13, 2007 | Fedders J Chassis A6J12E7A Air Conditioner
Heating & Cooling Logo
85 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
