Question about Maytag MER6772 Gemini Electric Kitchen Range
Light indicator when burner is turned on will not shut off.
The light on under the burner knobs that come on when the burner dial is turned on, will not shut off. The stove top is off but the indicator light will not go off.
  • 41 Answers
If there is one light for all the switches, you will need to unplug the unit, take off the top part of the back panel to get access to your switches. the indicator light is run to all 4 switches. you will need to unplug the wire that goes to the indicator light from each switch ( only one at a time ) and plug the unit back in each time. do this for every switch until the light goes out. whichever switch has the indicator light wire removed from it when the light goes out is the switch that needs to be replaced. if your unit has an indicator light for each switch, then just replace the switch that is above the indicator light. Joe
Posted on Dec 12, 2008
How to light grill
switch the dial to the indicator which shows the top grill,usually this is a black line with a squiggle under it.
Sep 15, 2016 | Ovens
Jenn-Aire Model CVG4380 gas stove top. Why doesn't igniter work?
Under your knobs are burner switches, 3 of them are the same, so this will be a hit and miss on getting them but possible. Each burner should trigger the ignition system. This will be needed to be inspected to find out which one needs to be replace. If you get the right person to look over the unit they could tell you if it can be repaired. I worked on one about 3 years ago and it worked out fine. Good Luck and I hope this helped.
Apr 11, 2016 | Kitchen Ranges
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
Element light stays on after all power control knobs are in off position?
Good Afternoon Cindy,
I see that you are having trouble with the element light staying on after all power control knobs have been put into the off position on your Frigidaire range, model# FEF366EC. The Element ON indicator lights will glow when one or more of the surface elements are turned ON. A quick glance at these indicator lights when cooking is finished is an easy check to be sure all control knobs are turned OFF. The Hot Surface indicator light will continue to glow AFTER the control knob is turned to the OFF position and will glow until the heating surface area has cooled sufficiently. I suggest resetting your appliance by shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "clock" button, and then you will press and hold down either the up or down arrows until the correct time appears. Try turning the burner on that the indicator light stays on the most. When you turn it off if you are still having trouble with the element light staying on, I suggest contacting a local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire FEF366EC 30" Freestanding...
I have a Rheem gas furnace, model # RGAA-100C and need help lighting the pilot. The instructions on the metal plate tell me to set the valve to off, then to pilot, push the valve down until lit, and then...
Hi, follow what I say and it is very easy. The knob that says off, on, and pilot, is where you need to start. You don't want to turn it off now, as its been off for awhile now. Turn the knob slowly pushing down on it until you fill it go down. The knob will go down believe me. When this happens, keep holding it down as this is what starts the gas to the pilot which is back under the burner, under it. Just take a flash light and you can follow the aluminum tubing back and where it stops is where you light it with something long with a match in it or a small rolled up paper. Keep the knob down the whole time you are lighting it. When it lights, keep the knob pushed down for about another minute. Then slowly release the knob and the pilot should stay on. Once you have it on, turn the knob to on, not off. If you turn it the wrong way, it will go off and you will need to start over again. Once it stays on by itself, turn your thermostat up for heat and the burner will light and come on. Just remember that the pilot where you light it is where the tubing goes back under it, as the pilot gas goes through it. You will need a light. Look at the knob with a good light and it will tell you which way to turn it. In the pilot position, the knob will press down to let the pilot gas in, and you can reach back and light it. Then turn knob on. Pilot should stay light. Turn on thermostat and it will fire up. Let me know how it goes. You may have to try a couple of times.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 05, 2010 | Heating & Cooling
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
Grill does not heat over 250 degrees
Here is a couple of things to do.
Make sure your tank is filled.
Straighten Fuel hose, so it is not bent or kinked.
Does your front burner light with a match? If it does light then check the Crossover Ignition System.
Also, It could be the way the unit is turn off.
Try following thses steps, this will help to reset the excess flow safety device.
Turn all burner control knobs and the cylinder valve OFF.
Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve on slowly. Then go ahead an light your grill.
Fireplace-girl
Jul 22, 2009 | Weber Genesis Silver C Grill
Kenmore stove surface unit light stays on
When the indicator light does not shut off when the burners are turned to the off position, this indicates one of the infinites switches are shorted. If comfortable with electricity, unplug the unit and remove the rear cover exposing the infinite (burner) switches. Using a bright flashlight, shine directly on one of the switches and you will see the following markings. L1 - L2 - H1 - H2, and then the Letter P. This letter P is for the pilot light. Since there is no way of determining which switch is shorted, remove the wire from the letter P on one switch. Isolate the wire removed so it is not touching anything. Place a piece of black electrical tape around the end to be safe. Next, plug it back in. If the light is still lit, move on to the next one until you have found the switch that once the wire is removed, the light does not light anymore. Replace that infinite/burner switcha nd all is well. If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Feb 13, 2009 | Kitchen Ranges
Maytag MER6772 Gemini Electric Kitchen Range Logo
692 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
