Question about Infinity 475A Car Audio Amplifier
Both Positive and Negative Speaker Wires Mixed With Truck On
My sons truck was running when he crossed the two speaker wires. The amp went into protect mode and went back to regular. Fuses are fine and so are the cables but you can hear engine noise when started. Whats wrong?
  • 58 Answers
WHEN U CROSSED THE WIRES U POPED A WIRE LEAD LOSE, CHECK ALL YOUR CONNECTIONS.
GOOD LUCK
Posted on Dec 12, 2008
I need a factory speaker and radio wiring diagram for a 2009 dodge 2500 quad cab truck
This is what my books show.
2009 Dodge Ram 2500 Car Radio Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Amp Trigger Wire: Dark Green/Red
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 12, 2012 | Cars & Trucks
How do I connect my nitro 1000 watt amp to get thr most bass .i have two 15 vx kickers
If you have the Nitro bmw-482 running it at 2 ohms will give you the max output (its not 1ohm stable so don't run it that way). First run your two dvc speakers parallel (run both negative out puts together and both positive out puts together on each speaker). After this you should have 1 positive and 1 negative wire from each speaker (4 wires altogehter). This will give you a 1 ohm load which your amp can't handle, so you have to run the 4 wires in series to create a 2 ohm load. Now take the positive wire from 1 speaker and connect it to the negative wire from the opposite speaker. Thats how to run in series. Now you should have 1 positive wire from 1 speaker and 1 negative wire from the other speaker which is 2 ohm load. Your amp sould be bridgeable, so connect the positive wire into the correct terminal of your amp and the negative wire into the correct terminal of your amp according to where to bridge it (positive into left positive, negative into right negative) . That will give you a 2 ohm load bridged which is the most power you can get out of your amp 300 watts. Medium quality amps are over rated so you will never acheive the 1000 watts as advertised.
Dec 01, 2011 | Car Audio & Video
Please help me install a kenwood cd player in a 1995 GMC sierra truck the plug is cut off and i dont know the wires
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Nov 27, 2011 | 1995 GMC Sierra C1500
Wiring colors ford ranger 1992 &pioneer deh 3900 mp need to know which wires are which thanks
I suggest check this diagram
DEH-3900 Installation Manual -->> DEH_3900MP_CRD4131_installation_manual
1992 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope helps.
Oct 03, 2011 | Pioneer DEH-3900MP CD Player
Need diagram on wiring harness for 2002 ford f150 showing ground wires and wiring for starter/celanoid can you help?
If you need it for the truck car radio then some of these sites will help you. http://www.fordf150.net/forums/viewtopic.php?t=68020 http://www.modifiedlife.com/2002-ford-f150-truck-car-radio-wiring-diagram/ And from what i understand this is the wiring: Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio ground wire: Black/Green
Car Radio Illumination Wire: Light Blue/Red
car stereo Antenna Trigger: Blue
Left Front Speaker Positive Wire (+): Gray/Light Blue
Left Front Speaker Negative Wire (-): Tan/Yellow
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Orange/Light Green
Left
Rear Speaker Negative Wire (-): Light Blue/White
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
I put a lot of work into this answer so i hope it helps. If it doesnt then contact me and i will get it right for you but this should be the correct diagram.
Jun 29, 2011 | Ford F-150 Cars & Trucks
I need the color codes for my radio wires in my 1995 mazda ranger truck
Hi, thanks for using FixYa.
1995 Mazda B2600 Car Radio Installation Guide
Car Stereo Amp Trigger Wire: Blue
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Jan 02, 2011 | Mazda B-Series Truck Cars & Trucks
What wires go together for the constant on a 94 ford ranger
1995 Ford Ranger Pickup Truck Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Green/Purple Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: Blue Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 6 1/2′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Orange/Light Green Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Car Audio Rear Speakers Size: 5′ x 7′ Car Audio Rear Speakers Location: Rear Corners Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 14, 2009 | Kenwood Audio Players & Recorders
Stereo wiring for my 1997 jimmy
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
Car Stereo Antenna Trigger: Pink
Good luck and hope this helps.
May 13, 2009 | 1997 GMC Jimmy
Puttin new speakers i dont know what color the stock speaker wires are
2002 Chevrolet S10 Pickup Car Stereo Radio Wiring Diagram
Car Radio Switched 12v+ Wire: Dark Green
Car Stereo Dimmer Wire: Violet/White
Apr 16, 2009 | 2002 Chevrolet S-10
Wire radio diagram
1987 Ford F350 Truck Car Audio Wiring Guide
Car Radio Ground Wire: Red or Black
Car Audio Front Speakers Size: 6′
Car Audio Rear Speakers Size: 6′ x 9′
Mar 01, 2009 | 1987 Ford F 350
Infinity 475A Car Audio Amplifier Logo
235 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
