Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Vegetable draw is freezing the vegetables
I have a whirlpool gold refrigerator. I have set the control for the vegetable draw in both extreme positions and the same result occurs. The vegetable freeze
Change the filter. Fruits Vegetables
Posted on Sep 11, 2015
  • 41 Answers
If you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Posted on Dec 12, 2008
Why are my vegetables freezing in the crispers and my juices in back of the refrigerator freezing?
Someone has either ran your thermostat to the coldest setting. Most thermostat controls should be set at mid position, On most that is a 5 setting. If this does not help, your thermostat probably is not functioning because the contact in thermostat may have welded together and needs replaced.
Sep 25, 2014 | Refrigerators
Why do my vegetables freeze
Do you have frost buildup on the rear wall of your freezer? What is the model number for your Whirlpool? It is important that you provide the model number so I can see what may be causing the freezing temps in the fresh food section/crisper. Thanks JT
Feb 06, 2013 | Whirlpool Refrigerators
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Vegetable draw overcooling vegetables are almost to the freezing point
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 13, 2011 | Amana ABB1927DE Bottom Freezer...
I have a problem with items freezing in the refrigerator. I have the setting as warm as I can put it. It even freezes lettuce in the vegetable crisper.
You need to change the cold control. Call Bi Coastal Appliance Parts @ 1-800-673-1262 give model and serial number.
Nov 16, 2010 | Whirlpool Refrigerators
Vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 17, 2009 | Refrigerators
Vegetables freezing
Most side by side refrigerators use the freezer to supply cold air to the refrigerator side. They use a duct through the wall between the two sides to let COLD air come into the refrigerator. That cold air will be blown upon the drawers at the bottom, where you are storing your vegetables.
There are two adjustments - or three, depending that will change how the air comes through. The freezer control will set the base temp for the freezer, and thus the temp of the air coming into the reefer to cool it down. The reefer can have a movable vane that increases or decreases the amount of air flowing in from the freezer, the vane being operated at the command of the refrigerator temperature control. Some have a movable plate that limits the flow of air on a fixed basis.
Set the freezer for 0F. Adjust the refrigerator setting, starting in the middle of the range, until a thermometer on a middle shelf, will read at 40F. Take your time, and check once an hour or so, to let it stabilize.
Make sure that you are not blocking airflow in the refrigerator, as the air must circulate to avoid too low a temperature in spots, such as you are experiencing.
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Vegetables are freezing inside vegetable bin
Most likely your refrigerator is set at too cold a setting. Just turn the temperature adjustment to a warmer setting.
May 03, 2009 | Refrigerators
Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Apr 14, 2009 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
2,215 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
