Question about Refrigerators
Ice block at back of bottom freezer
I have a Maytag bottom freezer refrigerator and the freezer back wall keeps icing up so eventually the refrigerator gets warm. I have tried to defrost the ice block at the back...tonight is the second time in a month I have done this. The water/condensation pools at the bottom of the refrigerator freezing the pull out drawer in place.
Help!
  • dean384 Jan 15, 2009
    Diplomat Fridge Freezer keeps icing up
    Habit-Forming:
  • 171 Answers
The freezer heater needs replacing, it's about $50.00 bring the model number to your local part place retailer. and they can seld you a new one.
Posted on Dec 12, 2008
Why does ice keep forming in the bottom of the refrigerator
If you are referring to ice forming on the floor of the freezer, it's a result of a blocked defrost drain. Contact Maytag to send out an authorized service company to make repairs. There is a drain kit that is installed at no cost to you.
Sep 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Ice forming on the bottom of the freezer
The ice is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water drining into the pan where it will evaperate,it's pooling on the freezer floor and freezing.By pulling the ref. from the wall there will be a tube behind teh service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps,
Gene
Aug 04, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Mbf2256keq1 bottom freezer back wall of freezer gets covered in ice and refrig doesn't get cold. We have to shut off for a day to let it defrost but will only last a couple of months until it does it...
Dear friend! Most of the customers are not advised by supplier how to use fridge and maintain.
Please keep thermostat at 5 degree or less little. If you keep temp in minus will make over freezing and also defrost timing will be after long time. It will create over ice formation around the freezer by which the freezer fan will be blocked or disturbed to work. Resulting to less or no temp in fridge compartment. Please ensure, thermostat,defrost timer and heater are working properly. Thanks.
Feb 02, 2011 | Maytag MBF 2256 Bottom Freezer...
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Maytag side by side refrigerator ice forms at the bottom of freez
Your drain is probably plugged. Remove the back panel in the freezer and keep squirting hot water down the drain hole with a turkey baster or something similar until it clears. The drain hole is located at the bottom of the coils in the freezer section. Your refrigerator goes into defrost every 8 to 10 hrs. When this happens, it melts the ice on the coils, which in turn, runs out the hole where the drain is. If something like algae is blocking or plugging the hole, it will plug up causing water to freeze over the hole. The water has nowhere to go but out the door.
Jun 02, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Ice on the back wall of the side-by-side freezer and no ice
Possible circulation fan has quit, or defrost element is not working, call service.
Apr 20, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Refrigerators Logo
188 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
