Kenmore washing machine will not spin, makes noise but doesn't move.
  • 71 Answers
Sounds like you have a direct drive washer and the coupling is sheared
Posted on Dec 12, 2008
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Whirlpool washer problem spinning
If it makes noise but moves, it's your motor - it it doesn't move at all, it's the belt. Noise and won't move, get a new washer. Check the BELT first - that usually is the problem.
Jul 22, 2012 | Washing Machines
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
Making loud noises on spin cycle. The whole
i have this same model and mine does the same exact thing.
Dec 12, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Kenmore 90 series won't spin
Perhaps your belt is off. The belt should "give" half an inch after it is fitted; too tight or too loose otherwise. Replace if necessary.
Dec 28, 2007 | Washing Machines
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
