Question about Kanecal CCD Barcode Scanner -USB connection (swusb)
CCD BARCODE SCANNER WILL NOT TRANSMIT DATA
IT IS A WASP N1181 CCD SCANNER AND I AM USING IT ON A DELL LAPTOP WITH A EXTERNAL COMPAQ KEYBOARD AND A PS/2 USB ADAPTER THE KEYBOARD WORKS FINE THE SCANNER MAKES 1 NUMBER JUST SCROLL ACROSS THE SCREEN AS IF I WERE HOLDING THE NUMBER DOWN ON THE KEYBOARD
Tip
How to connect barcode scanner to your pc
In order for them to be useful, barcode scanners often have to be connected to computers. We will recall that in virtually all cases, the data which gives meaning to the barcodes they read is stored in databases, which are in turn hosted on computers. What the barcode scanners are meant to do, then, is to transmit the data they scan to the computer, with the computer checking that data against the database in order to assign meaning to it. In most cases, then, scanners without computers will tend to be quite useless. For a scanner to be useful, it has to be connected to the computer. And what we are interested in, for this discussion, is gaining an understanding of the ways through which barcode scanners connect to computers (at the simple, physical, external level).
As it turns out, there are four main ways through which barcode scanners connect to the computers which host the databases upon which they depend:
1. Serial port connection: this is where the scanner comes with a pin which you simply hook onto the serial port of your computer (like where you would hook an extra mouse), and thence connect the barcode scanner to computer. It was, arguably, the first method for connecting barcode scanners to computers to be developed. Its disadvantage is that it is not a plug and play approach. You have to go through quite a lengthy installation process for the barcode scanner, when you go this way. Furthermore, should the scanner 'hang' somewhere in the middle of a computing session, you don't have the option of just unplugging it and then plugging it in again to see whether it will work. Instead, you have to restart the whole machine again, and this can be very disruptive, for instance in the midst of a shopping checkout for a hurried customer. In this system, a scanner would also need specialized software to connect to various computers, meaning that there was no universality in scanner usage.
2. Keyboard wedge connection: this is a connection method where the barcode scanners are put in somewhere between the keyboard and the computer as a 'wedge.' It is something of an improvement on the serial port connection.
3. USB connection: this is what is to be found on most scanners, today. It is where you connect the scanner to the computer using any USB port. A scanner made in this way can, therefore, be used with pretty much any computer. Should it stall midcourse, you have the opportunity to just unplug it, and plug it again, to see if that solves the problem (which it often does). It is also convenient, because in this approach, connecting the scanner to the computer becomes as easy as connecting a USB flash disk to the machine.
4. Wireless connection: this is the emerging technology in ultra-modern scanners, where using systems such as Bluetooth, they are able to connect to the associated databases wirelessly.
on Oct 05, 2010 | Computers & Internet
My WD fell on the floors and never worked properly since. I since purchased a hard drive enclosure and transferred old SATA drive to an enclosure because it failed to be recognized by my computer and the...
Hello jazzmania67
The best solution in this case is to use a recovery tool to recover and store your data on another drive
Free Recuva works fine : http://download.cnet.com/Recuva/3000-2242_4-10753287.html
Do not try to recover all at once but each category at a time , documents , pictures , music ...etc...
If it fails , try this one . It's not free but very efficient : Tenorshare Data Recovery. It can recover data after deeply scanning your hard drive to look for lost data due to unwanted erasing , system sabotage, virus corrupted partitions,drives crash, physical damage,ect.. http://www.any-data-recovery.com/product/index.htm
If you still don't have success , you will have to go to a recovery office but let's hope not because it will cost you a lot of money .
Regards ,
fanaudi .
Mar 29, 2011 | Western Digital My Book Essential Edition...
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from support.symbol.com.
The P370 is NOT supported by the newer 123Scan2.
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
Will not transmit to Shop and Scan website when transmit button is pressed . drivers installed from cd provided, new usb lead connected and green light shows on scanner, test scan done from barcode on...
Did you ever get it to transmit the barcodes?
I'm having very much the same problem. Got the error 3 message first, then was told to delete the add on in manage add ons. Now i get an error 2.
Jun 13, 2010 | Opticon OPN 2001 Mobile Data Collector...
Get usb device unreconized when I plug wcs3900 into usb port
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Mar 05, 2010 | Wasp Nest WCS 3900 CCD Barcode Scanner...
I cannot get my opticon barcode reader to work with my wirless keyboard. I have a Dell computer, and a Microsoft wireless keyboard I have the hand-held CCD Wedge Interface (25-wedge-06 Opticon Bar code...
Hi!
Keyboard Wedge Barcode Scanners are sometimes tricky because they will not operate if the keyboard is physically attached to the Scanners' "Y" cable. A possible solution would be to attach an additional keyboard to the "Y" cable and simply set it aside un-used. (This would allow you to continue to use the Wireless Keyboard; which I assume is USB). I may also be able to program the scanner to operate in a Laptop Mode which would allow you to operate successfully as-is. I would need your exact model number to investigate if this is possible.
Hope this helps!
-Dave
Dave Krause
Founder, Bluesky America's GetOpen.com
720.771.5194 Direct 888.7.GETOPEN Toll-Free
Apr 02, 2009 | Computers & Internet
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Feb 07, 2007 | Wasp WWS800 Handheld
Kanecal CCD Barcode Scanner -USB connection (swusb) Logo
783 people viewed this question
Top Kanecal Computers & Internet Experts
David Payne
David Payne
Are you a Kanecal Computer and Internet Expert? Answer questions, earn points and help others
