Question about GE Profile PDW8400J Built-in Dishwasher
Touch panel buttons not working
I have a GE profile PDW8980NSS dishwasher. Some of the buttons onthe touch panel are not working when I press on them. DoI have to replace the touch panel and where canI go to get the part. i have looked at a number of sites.
  • nmedeiros590 Dec 15, 2008
    Thx for your reply.
    I have been to that website. I have used it in the past for other appliance parts, but I can seem to locate that touch panel part for this dishwasher. Can some one help with a part number or other so that Iam sure what I am ordering
    cheers
  • GE Master
  • 13,433 Answers
Parts are avaiable here http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Simply enter the pdw8980nss you said on your original post into the  model field and you will find the parts.
Check the connectors first, if they seem fine it maybe the touch panel.
Posted on Dec 15, 2008
    Master:
  • 479 Answers
U can get this touch pads at  www.repairclinic.com and yes its the touchpad problem and needs replacement for sure.
  • GE Master
  • 19,396 Answers
Try unplugging power cord for ten minutes, if this does not clear the error, you may have to replace touchpad assembly.
You find parts by entering model number here.
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
Touch pad won't change settings, stuck on rinse cycle
It seems like, it is touch pad control panel problem and depend on brands, without knowing brand name and model number price of touch control could be between $100 less to $200 or more plus labour to replace
Sep 08, 2013 | GE 24 in. Profile PDW9880JSS Built-in...
Pdw 9800 jooww When power came on after outage, touch panel doesn't work and there is a constant beeping noise.
Try pressing two control buttons side by side in the center of the panel. The result will light all the buttons on the panel. A test mode will follow before it resets itself.
Sep 24, 2010 | GE 24 in. Profile PDW9800J Built-in...
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
I have a ge profile pdw7800 which will not start. the problem seems to be with either the circuit board, or the touch panel. Some buttons on the touch panel work, and others dont. Please advise if this...
I'm having the same problem with my GE PDW7800's touchpad. the buttons to the right of the Start button are dying. I'm now having to play a dance between with the "button lock" mode and Time Delay to get it started. Unfortunately, the capacitive touch panels are delicate and have a limited lifespan. You're looking at replacing the touchpad, or buying a new dishwasher
I'll be replacing mine eventually, but the lowest price I've seen is currently $230, so this is a fairly expensive repair. (That is why I've not replaced it yet. I can play the button dance game a little longer, but eventually it will cease to function at all.)
Jul 16, 2010 | GE 24 in. Profile PDW7800 Built-in...
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
148 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
