Question about Hunter Fan Company 5/1/1 Programmable Thermostat
MY THERMOSTAT TEMP. WILL NOT REACH THE PROGRAM TEMP.
MY THERMOSTAT IS SET AT 78 DEGREES BUT ITMAINTIAN 73 DEGREES THEN SHUTS OFF. THIS IS TO COOL OF A TEMPERATUE IN MY HOME.
3 Suggested Answers
  • 5 Answers
SOURCE: trouble with newly installed thermostat
did you program your own temps, if not i believe this is part of default program!
Posted on Jul 11, 2008
kachbibi1
  • 979 Answers
SOURCE: I set temp to 74 and stop at 70 and decresing.
The only thing I can think of other than being just old and worn out is that by design it may not be set to run but so much at a time. Has this always done this since you have had it? It may be needing calibration. One thing you can try is to set it at 2 degrees higher than you want it and then it would shut off at the temp you actually want.
Posted on Mar 04, 2009
My thermostat is set to 73 degrees when i get home at six it is set at 75 during the day when im not home the past couple of days it wont get to 73 it actually goes up to 76 77 it is working cool is on why...
may need charged a out of adjustment can cost lots is it old unit is outdoor temp. very hot may have trouble catching up to setpoint.on a 95 degree day good luck.
Jul 07, 2010 | Honeywell Electronic Programmable...
AC Thermostat is set to 78 but wont cool past 79 or 80
If your unit is running 24/7 you are either low on charge or the unit is to small for your house.
A 20° temperature difference is about normal for the room air vs the air coming out of the ducts, but the room air and the leaving air should keep getting colder and colder.
An air conditioner should cycle approximately 3 maybe 4 times in an hour if it's properly sized.
As for the thermostat thermometer they are very cheap and are more for reference than actual temperature, so if 78° is not comfortable, then you should set it lower but not rely on thermostat being accurate or what the thermometer is saying as long as it is consistent.
The air conditioner and thermostat can also be set below 78°, there's a lot of people set them at 72° and below with no problems.
the only thing is if you have real low humidity you'll need to watch indoor coil or the suction line (the big line) on your outdoor unit and make sure it doesn't freeze up on you.
Sep 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
UNIT RUNS ALL DAY AND NIGHT WILL NOT COOL UNDER 78 DEGREES-ALSO WILL NOT EVEN HOLD AT 78 DEGREES. HAD THIS UNIT SERVICED OCT 29, 08. IT IS STILL UNDER WARRANTY-BUT WAS CHARGED 700.00. CAN'T AFFORD TO GO...
it sounds like thermostat which tell unit to turnoff
and set the temp. you can test them with hair dyer buy putting it on heat see what dose then cool. The display should show the temp. if so then it should shut off or turn on is. If not could be a bad thermostat. Or is the thermostat in a hot spot in the house is should be near the return. Hope this helps. Yes I do for living Paul
Jun 19, 2009 | Heating & Cooling
Temp shows 2 degrees warmer than what is was set to
sometimes the furnace does a better job than anticipated, i wouldn't worry about it, especially if the furnace shuts off.
the setpoint is the temperature you want it to be
cycle lenghts are determined by how much recovery you are requesting. for instance, in the morning when you wake up, you want the temperature to be at its setpoint. what the thermostat will do is make the furnace run a limited lengths during the recovery process.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
54 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
