Nikon D70s Digital Camera with 18-70mm Lens
Problem for Nikon D70s Digital Camera with 18-70mm Lens
The corners of my images are darker than the center at the telephoto end of my zoom's range. Is my ....
By LiZzIe - usenet poster
The corners of my images are darker than the center at the telephoto end of my zoom's range. Is my lens defective?
Best Solution
posted on Aug 08, 2005
Helpful)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
Probably not. This effect is called vignetting and it is common in consumer quality lenses. If the effect is not equal in all corners, then something may be misaligned and you should return your camera or lens for service.
Was this helpful?
Yes
No
Solution #2
posted on Jul 09, 2008
Not Rated)
cristtos
Rank: Apprentice
Rating: 0%, 0 votes
Sometimes a lens hood that is not designed specifically for the lens you have can “show” in the picture as the darkened corner.
It is easy to check if this is the case: remove the hood and take another picture in the same conditions and zoom level.
Was this helpful?
Yes
No
Solution #3
posted on Feb 04, 2008
Not Rated)
chansimon
Rank: Wiz
Rating: 80%, 59 votes
Usually vignetting happens at wide-angles rather than tele-photos. I wonder which lens you are using?
Was this helpful?
Yes
No
Solution #4
posted on Jul 29, 2007
Not Rated)
pbinder
Rank: Guide
Rating: 95%, 6 votes
You can also try to counteract this if you have Adobe Photoshop CS2 or CS3 if you shoot in RAW format on the camera. Open the photo in Photoshop's Canon Raw dialog (opening the RAW photo from photoshop should automatically pop up the RAW dialog) and then on one of the tabs you can adjust vignetting either making it darker to add this (some people actually want this look, usually in portraits) but you can move the slider the other way to actually make the corners lighter to try and even the photo out. If you do not know which tab does this, consult the help file.
Was this helpful?
Yes
No
Popular Solutions for Nikon D70s Digital Camera with
Questions and Unsolved Problems for Nikon D70s Digital Camera with
Do you recommend Nikon D70s Digital Camera with 18-70mm Lens?
Answer
Answer
card reader and menu display of my nikon d70s do not function anymore, after dropping the camera
Answer
CHA display were the counter numbers are
Answer
after i take a photo a " job nr" is flashing on the lcd display and it looks like it takes... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D70s Digital Camera with...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
