Question about Amana PTH153B50AE Air Conditioner
Amana pth153b50a where can i find a thermostat for a amana pth153b50a
    Genius:
  • 1,199 Answers
I would try www.sears.com parts dept...have make and model ready!
Please rate! !this is how we keep this website free
Thanl you!
Posted on Dec 13, 2008
Will a wireless thermostat work with my amana command 80 sse furnace?
Yes. A wireless thermostat will work on your Amana furnace. I like the Honeywell wireless thermostats. The only problem I have had is exceeding the distance between the wireless thermostats location and the control module that you mount and wire up next to the furnace.
Feb 07, 2018 | Amana Heating & Cooling
Bypassing thermostat on amana pth093a35ab
Hallo
I would highly recommend not doing that because the compressor won't know when to stop and then starts roughing liquid into the suction valve causing the compressor to stop pumping and a thermostat is much cheaper then the compressor but if you see the thermostat there's a Live going in, connect it with the out going Live and that would bypass the thermal switch.
Regards
Jun 23, 2016 | Amana Refrigerators
Replaced the thermostat and high limit regulator on my amana comercial dryer lea60aw but forgot to tag wires, starting from the thermostat on the blower, i'm not sure where the wires go to, i have
if i were there i could tell you.just think about it .the wires have to make a path all the way through the element.it should have a wiring diagram in the control panel that will help you trace the path.hope this helps.
Dec 04, 2017 | Amana Dryers
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Amana thermostat, is there a battery to change?
No. They may not be batteries. Many electronic thermostats use capacitors that are not removable. Some thermostats still use batteries but not all. Check with the user's manual of your thermostat for detailed information on use and troubleshooting.
Good Luck! :-)
Feb 24, 2010 | Amana Heating & Cooling
Hi there i have a client with an amana frigde sxd524ve fault is very ic ed up evap unit no fan running i defrosted unit and resarted system fan now running i believe defrost element and or timer may be...
Okay, rookie ;)
Amana fridges have problem with the defrost thermostat, which you may not notice without looking at the thermostat very closely. If the plastic cover on the thermostat is swollen or is higher on one side - replace the thermostat. Fan in these fridges is connected in series with the heater and the defrost thermostat.
... And finally 127 Ohms for a 110v heating element is too high, resistance must be lower. If you measure it through the defrost thermostat - separate them and check again.
Oct 14, 2009 | Amana SXD524VW Side by Side Refrigerator
Remote Thermostat
call the amana dealer nearest to you order one
Jun 06, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana oven arg7300LL oven and boiler do not work?
If it is the same as my Amana, it has a small switch in front of the thermostat switch. It is only a $15 part to fix it. I am searching for the thermostat and your question came up. I am sorry it is so late in response to your question. I am sure you have fixed it by now.
Dec 22, 2007 | Amana RanARG7302 Gas Kitchen Range
Heating & Cooling Logo
103 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
