Question about Labtec Webcam Pro
Can't transmit video via MSN Messenger
I recently sent a friend who moved away a Labtec Webcam Pro camera. She's having difficulty establishing a connection through MSN Messenger. She's only able to view herself on her display window. Any suggestions?
    President:
  • 2,961 Answers
As long as she is accepting your call when invited it should show up a little MSN advert then show your picture. The problem may be at your end, so check that you have the cam set up in settings and you both allow video to be accepted, ckeck all the web cam settings and menu options. If you haven't already, download MSN live messenger.
Posted on Mar 08, 2007
Will not work with MSN Messenger
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Set your webcam mic (if it has one as default)
Vista -
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jul 01, 2010 | Logitech Webcam
Not working with msn messenger
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Apr 06, 2010 | Logitech QuickCam Messenger Web Camera
How to configure logitech with msn messenger?
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Click 'Finish'
Dec 09, 2009 | Logitech QuickCam Messenger Web Camera
How to get labtec webcam to work on msn live?
We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
this is the error msn i get when iam trying to use my camera in msn messenger on all other i can use ? whats the reason ?
Oct 09, 2009 | Xirlink Promax Webcam
Connection drops when webcam is on on yhoo messenger
Normal 0 See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have there computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Jun 05, 2009 | Labtec Webcam Pro
My webcam does not work on msn
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use...
but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
May 17, 2009 | Logitech QuickCam Pro 5000 Webcam
Skype cannot find webcam
Normal 0 See section A. Skype the info below to setup the Audio & Video.
A. Skype Setup:
B. Yahoo Setup:
Apr 23, 2009 | Labtec Webcam Pro
Labtec msn problem
Hi, I am attempting to use the camera on ie as a video call problem is i can see a black screen. The camera is work as i can see myself on its software. I tried going to msn setting but have had no luck. it seems that the two the camera and ie
Jun 05, 2008 | Labtec Webcam Pro
How to connect to msn messenger
The easy way to send webcam videos in email is to use mailVU.com. It is free, and allows 10 minute recordings. No large file attachments to deal with.
Feb 02, 2008 | Labtec 961307-0914 Webcam
Labtec Webcam Pro Logo
184 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
