Question about Cats
. Where can I find an extra-large harness for my cat?
You can find a cat harness at http://www.wallyboypetproducts.com
Posted on Nov 05, 2012
    New Friend:
  • 36 Answers
The Lupine Patterned Harness has the right harnesses foryour cat.The Lupine Patterned Harness offers a harness that shouldfit cats that have a girth of 12 up to 20 inches.You can find a suitable harness for you in http://www.drsfostersmith.com/product/prod_display.cfm?c=3261+10634+2966&pcatid=2966
Posted on Jul 18, 2012
SOURCE:
2007 tl type s where is bank 2 sensor 1 oxygen sensor located. What is the replacement number of a sensor to kill Emission p0171 Notice and light
Oxygen sensors monitor the exhaust stream, comparing the oxygen content in it to the oxygen content of ambient air. When oxygen content is low, sensor voltage is high. When oxygen content is high, sensor voltage is low. The voltage created by the sensor is sent to the DME (engine control module) to help maintain a proper fuel mixture. The mixture preparation is used to keep the catalytic converters running at peak efficiency. The oxygen sensors used in E60 models covered in this article has four wires. Two of which are for oxygen sensor heating and two for the signal. The heater is used to get the sensor online faster. Previously, exhaust heat was used. One wire supplied a ground to the sensor for the signal, and the other was for the sensor signal.
Oxygen sensors should be replaced every 100,000 miles. In a perfect world that would be it. Wait until a specified mileage and replace the sensor. However, these sensors fail prematurely, set oxygen sensor fault codes and reduce fuel economy. In this article, I will show you how to identify the location of all four oxygen sensors and how to replace them. You will need an oxygen sensor socket to remove the sensors and remember to always work with a cool exhaust. Oxygen sensors are fragile. Do not drop, as damage may occur. Also, keep the sensor tip clean when reinstalling.
Oxygen sensors are laid out in banks, which refer to cylinders and in sensor numbers referring to before or after the catalytic converter. Bank1 or B1 refers to cylinders 1-3. Bank 2 or B2 refers to cylinders 4-6. Sensor 1 or S1 refers to the sensor before the catalytic converter. Sensor 2 or S2 refers to the sensor after the catalytic converter.
Remember that your car may have been serviced before and parts replaced with different size fasteners used in the replacement. The sizes of the nuts and bolts we give may be different from what you have so be prepared with different size sockets and wrenches.
Protect your eyes, hands and body from fluids, dust and debris while working on your vehicle. If working with the electrical system, disconnect the battery before beginning. Always catch fluids in appropriate containers and properly dispose of any fluid waste. Recycle parts, packaging and fluids when possible. Never work on your vehicle if you feel the task is beyond your ability.
Our vehicle may vary slightly from yours as models do change and evolve as they grow older. If something seems different, let us know and share your info to help other users. Do you have questions or want to add to the article? Leave a comment below. When leaving a comment, please leave your vehicle information.
Figure 1 Bank 1 Sensor 1 is indicated by a yellow arrow. Bank 2 Sensor 1 is pointed out with a green arrow. Large Image ' Extra-Large Image
Figure 2 Bank 1 Sensor 2 has a green arrow. Bank 2 Sensor 2 is shown with a yellow arrow. Large Image ' Extra-Large Image
Figure 3 Replacing sensors before catalytic converter: Oxygen sensors are located in the exhaust manifold. Remove the engine covers. See our tech article on engine covers removing. Locate the oxygen sensor electrical connectors at the right side of the engine above the exhaust manifold. Label or mark the wiring harness to aide during reinstallation. I suggest replacing one sensor at a time so you do not mix up connectors. Using an oxygen sensor socket, loosen the oxygen sensor connection to the exhaust manifold. Do not unscrew yet. Large Image ' Extra-Large Image
Figure 4 Replacing sensors before catalytic converter: Pull the wiring harness out of the mounts (green arrows) along the valve cover. Bank 1 sensor 1 shown, bank 2 sensor 1 is similar. Large Image ' Extra-Large Image
Figure 5 Replacing sensors before catalytic converter: Next, disconnect the electrical connector of the oxygen sensor you are replacing (yellow arrow). First, remove the electrical connector from the mounting bracket (green arrow) by pulling straight up. Once out, disconnect the electrical connector by pressing the release tab and pulling it apart. Note the wiring harness color and the factory sensors color code sensors to help when replacing. Locate the color of the sensor you loosened. Using an oxygen sensor socket, remove the oxygen sensor from the exhaust manifold. Lightly coat the new oxygen sensor thread with anti-seize compound. Install the new oxygen sensor and tighten to 50Nm (37 ft-lb). Then reroute the wiring harness and connect the electrical connector. Repeat if replacing both sensors. Then reassemble the engine covers and clear any engine fault codes using a BMW scan tool. Large Image ' Extra-Large Image
Figure 6 Replacing sensors after catalytic converter: Oxygen sensors are located in the exhaust, behind the catalytic converters. Working below the transmission, remove the transmission splash shield. See our tech article on lower splash shield replacing. Using an oxygen sensor socket, remove the oxygen sensor connection to the exhaust manifold. When reinstalling the sensor, do not allow the harness to remain twisted (green arrow). Be sure it is properly routed and tension free. Large Image ' Extra-Large Image
Figure 7 Replacing sensors after catalytic converter: Next, disconnect the electrical connector of the oxygen sensor you are replacing. First, remove the electrical connector from the mounting bracket (green arrow) by pulling it straight out toward the left side of the engine. Once out, disconnect the electrical connector by pressing the release and pulling it apart (inset). Note the wiring harness color, factory sensors color code sensors to help when replacing. Locate the color of the sensor you loosened. Using an oxygen sensor socket, remove the oxygen sensor from the exhaust manifold. Lightly coat the new oxygen sensor thread with anti-seize compound. Install the new oxygen sensor and tighten it to 50Nm (37 ft-lb). Large Image ' Extra-Large Image
Figure 8 Then reroute the wiring harness and connect the electrical connector. Repeat if replacing both sensors. Then reassemble the engine covers and clear any engine fault codes using a BMW scan tool.
Jan 02, 2018 | Cars & Trucks
My cat's collar came off she's a hyper cat and I'm trying to find a way to get it back on her every time I come up she runs away from me
If she is one year old or less then get her spayed or else she will act more crazy at times and then have a whole bunch of kittens. They will be super-cute then grow up and become annoying (for a longer time than they were cute) and require food and water and petting and also they will have a whole bunch of kittens. Then that will keep happening and you will get a large number of cats running around and they will often be hit by a car trying to run across and find food without proper parenting such as my cat Simon would do (though sometimes I think he teaches them to run into the road on purpose, if he doesn't like them.) Also I bet by now your cat has calmed down a bit. Cats have moods where sometimes they feel like HUNTING (especially around dawn and at twilight) and most of the time they feel like sleeping, so if you can catch her when she is getting into sleepy mode then you will have an easy time getting her collar on.
Jan 24, 2015 | Cats
Why does my cat act like its missing when i only turn on my heater/lights anything elec. when these things are off it runs great
The circuit that powers the fuel pump, ignition etc may have a bad connection in the wiring harness where the plugs come together. When extra electrical loads are being fed current through the plug connection there is voltage loss at the plug joint. Thy unplugging the multipoint connector where the wiring harnesses join together around the fusible links etc. You will be able to recognize the culprit by its discoloration due to overheating in the plug. Replacing connector pins and plug clips should take care of it.
Jul 30, 2014 | 1993 Mercury Topaz
How much do dog harnesses cost and where can I buy one for my dog?
This really depends on the size of your dog and the style of harness you want. The price range from small to large harnesses ranges from $6.99-$54.99. I suggest looking around to find the right harness for both your dog and your wallet!
http://www.petmountain.com/category/58/1/dog-harnesses.html
http://www.nextag.com/extra-large-dog-harness/compare-html
http://www.petsmart.com/family/index.jsp?categoryId=2767069
Jul 19, 2012 | Pets - Others
How far long should I hold the harness when I walk with my cat?
Walking with you cat is different from walking with your dog, you should give your cat to lead the way therefor the harness should be long enough to give your cat the space he needs, around 1.8-2.4 meters.
Jul 18, 2012 | Cats
Which cat harness is the most comfortable for my cat?
I strongly recommend The Kitty Holster cat harness. It is a comfortable, soft and secure cat harness that will suit right for your cat.
Jul 18, 2012 | Cats
What's the recommended length to a cat harness?
You need to measure the girth around your cat's chest, behind the front legs in order to size your cat for a harness. This is the harness size you should purchase You can watch a video demonstrating how to do it right at http://www.drsfostersmith.com/media/players/video.cfm?videoid=209
Jul 18, 2012 | Cats
Can cats walk with leashes?
Putting a cat on a leash is a great idea because a cat aloneoutside is a very bad idea! With aleash, your cat can be indoors and outdoors and you can be aware of what they'redoing at all times. If nothing else, I'msure many birds would be pleased that your cat is no longer roaming thestreets! There are leashes madespecifically for cats and they come with a harness for maximum comfort.
May 15, 2012 | Pets - Others
I saw that you can buy cat harnesses,
Cat leashes are agreat way to train your cat and some people even like to take them for a walk.If you want to use one you should start from an early age so that the kittenwill get used to it.
May 14, 2012 | Cats
Change the print size
Go to you control panel, open and bring up Display (properties). Click on Appearance and check to see that "Font Size" reads normal. I tried it on my Computer just now and the change to extra large is frightening. :D
Jan 01, 2010 | Dell Computers & Internet
Cats Logo
148 people viewed this question
Top Cats Experts
Ruth summersides
Tom Chichester
RANDY POWERS
Are you a Cat Expert? Answer questions, earn points and help others
