Question about Mitsubishi VS-50609 50" Rear Projection Television
V-Chip The parental lock blocks any chanels with a rating of TV-14, it is a 2001 model vs-50609. New to us and do not have a manual, is there a way to go around it because we do not know the 4 digit code to get rid of it?
    Problem Solver:
  • 16 Answers
Turn on tv....press menu 0-1-7-0......make sure initialize is highlighted and press enter....This will default the tv to the original settings..........Do not press enter if anything else is highlighted............Turn tv off /on you should be ok.
Posted on Dec 21, 2007
Remove child lock
See the instructions beginning on page 40 of this manual: http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
Jul 17, 2013 | RCA F32650 32" TV
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Jun 17, 2013 | Televison & Video
No chanels
The TV is locked electronically. To unlock it, you must have its remote control. If you have its remote control,
Lock the controls to activate the changes using item six on the "Parental Controls" menu. If you wish more details abut RCA TV unlock proceedings, check this site.
Jan 23, 2013 | RCA F27665 27" TV
How to take a childlock off a daewoo 22 inch tv model- dlt-22w4t
Sep 20, 2012 | Daewoo DLT22W4T 22 in. LCD TV
How to unlock childs security?
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
Child lock
  • Step 2 Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
  • Step 3 From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
  • Step 4 From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
  • Step 5 Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
  • Step 6 Lock the controls to activate the changes using item six on the "Parental Controls" menu.
  • Nov 30, 2009 | RCA Mikomi 5290925 15 in. LCD TV
    Can't get the child lock off
    You can use theV-Chip Parent Lock to
    Block or Allow programs based on the
    ratings sent by the broadcast stations.
    The default setting is to allow all programs.
    You can block programs by the
    type of program and by the categories
    you want blocked. Or you can block all
    programs during a specific time period.
    To use the V-Chip Parent lock, you will:
    • Enter a passcode
    • Select theV-chip ratings and categories to block
    • Select theV-chip hours to lock and unlock for television programs
    • Select lock by time
    Enter a Passcode
    MENU
    I. Press _ to display the Main Menu.
    2. PressAorV to select V-Chip Parent Lock.
    PressE_ R,
    3. Using the number keys, enter four numbers. To
    delete a character and move back one space, press
    CANCEL ENTER
    . Press _ to set the passcode and go to
    theV-chip ratings menu.
    MENU
    4. To exit without entering a passcode, press _ to
    HOME
    go to the previous menu or _ to return to
    television viewing.
    IMPORTANT
    If you forget your four-digit passcode, please
    see Appendix 3 : Procedure for Bypassing the
    After you set the lock, you will need the secret code in order to:
    • view a locked program,
    • view the locked TV, or
    • cancel the lock.
    If you forget the code, you can view the locked TV without entering the code. To do this, simply
    press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
    code is requested. Unlocking theTV this way is temporary.
    To change or permanently cancel the lock:
    I. Turn on your TV. If the TV requests your secret code, press
    and_ at the same time.
    MENU
    2. Press _ to view the main menu.
    3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
    4. The on-screen display will ask for your current passcode. Press
    and _ at the same time.
    5. The on-screen display will now ask you to enter a new code:
    MENU HOME
    • To cancel the passcode permanently, press _ or _ .
    • To change to a new passcode, use the number buttons to enter a
    new code, then press E_R,
    IMPORTANT
    You must use the remote control included with this
    TV. You cannot use a remote control from another
    Mitsubishi component and you cannot use "Univer_
    sar' remotes from other manufacturers.
    65
    Nov 24, 2008 | Mitsubishi VS-55707 TV
    Mitsubishi parental control reset for tv model vs-5061
    I can help you unlock your Mitsubishi HDTV V-Chip.
    Please follow these steps to bypass the vchip or reset the V Chip password.
    I hope that helps.
    _______________________________________________
    Reset Mitsubishi HDTV VChip Password
    Bypass Mitsubishi HDTV Front Panel Lock
    Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
    Password
    If I knew the model number I could tell you where to find your manual. I'll give you a link to the website that can help find your manual at the end. If you haven't already tried here is another method that may work.
    US V-Chip TV Rating Limit
    The V-Chip TV Rating Limit lets you decide which TV programs can and cannot
    be viewed.
    To set TV programming limits:
    1. Choose Parental Control from the MAIN MENU. If Parental Controls have
    previously been locked, you must enter your password.
    2. Highlight and select US V-Chip. Then select V-Chip TV Rating.
    3. Once you get to the V-Chip TV rating limit screen, use the arrow buttons
    and OK on your remote to change the status of a TV program rating or
    content theme from View to Block.
    4. For TV rating limits to take effect, lock Parental Controls by accessing the
    Lock parental controls menu.
    The following sections give you more details about how to change the status of
    TV program limits.
    Note: If you forget your password, follow step one above to get to the
    password entry screen. Then press the VOL+ and CH+ buttons on the TV's
    front panel at the same time for at least 8 seconds. You will receive an
    on-screen message that Parental Controls have been unlocked once y
    Or try this link to help find your particular model number and download your manual. http://support.rca.com/index.html
    Jan 03, 2008 | RCA TruFlat 27F520T 27" TV
    Mitsubishi VS-50609 50" Rear Projection Television Logo
    88 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
