Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
I have a yard machine snowblower that will not start
The recoil starter will not turn at all
  • 1 more comment
  • funari1 Dec 12, 2008
    The engine is seized, the rope only pulls out a short distance.
  • cump Jan 28, 2009
    my mtd snowblower ran fine for 1.5 hours. then my son used it for maybe 20 minutes. said the engine kept stalling out (but i believe that was due to the wrong gear selected. oil level is good.
    now when you pull the starter rope it acts as if it is locked, or a seized engine. my question is can the transmission lock out the engine?
  • Kenny W May 11, 2010
    Is the engine seized ? When you pull the rope, does it pull out a short distance and stop ? or does it pull all the way out but not engage to turn the engine over ?
    Problem Solver:
  • 7 Answers
If the engine is infact seized, then it will have to be re-built or replaced. It was probably run with very low or no oil at all. You may be able to get a short block for your engine. All you would need to do is reuse your cylinder head, flywheel, carburetor, ignition modual, recoil houseing, fuel tank, governor linkages and controlls. The engine block and all internal parts would be replaced. It is far cheaper to just replace the engine rather than re-build it unless you are able to do it yourself and save the labour cost.
Posted on Dec 12, 2008
My snowblower isn't starting
If it's the starter that makes a humming noise then you need to check the starter out. the gears could be stripped or even a tooth missing so it won't grab the fly wheel. Try pulling the start rope and see if that makes a difference. My Craftsman 8 horse has a recoil starter as well and I quite often use it as well. I don't always use the electric start.
Jan 10, 2016 | Craftsman Snow Blower / Snowblower Bottom...
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Nov 10, 2014 | Garden
Yard Machine Model 21a-121r900 tiller's pull starter recoil pully slipping
Bend the ears on the flywheel so that they are 90degrees. They are not lining up right.
Feb 16, 2013 | Mtd Garden
How do I replace the starter pull cord on a Yard Machine 21 inch rear bag mower
New "powermore" engine? recoil rewind starter comes as a complete assy. If the spring is broken this is your only option
Oct 28, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I was using the lawn machine 31cc tiller today, the black handle with the string flew off (about 20 ft), I was able to re-thread the string back through the hole and handle but now I have no recoil. ...
You need to tension the spring also. On youtube donyboy73 has good video on how to do this and he shows you how to adjust string tension with the string still attached. I think it is in a video about Tecumseh engine/snowblower recoil starters. If you can not find it, let me know and I will write it out for you.
Sep 09, 2011 | Yard Machines Garden
Snowblower will not start.Recoil starter is lock and electric starter is not working.
You may have to remove the recoil starter. Be careful, the spring, etc. may have disconnected from the recoil starter housing. There are probably 3 machine screws to remove to get the starter assembly off.
Then try the electric start.
Starter assemblies are a standard repair part.
Let me know if this helps.
Gary
Dec 18, 2010 | Garden
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
1,308 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
