Cd shelf unit stuck in standby
Apparently my RCA RP9150 CD shelf unit is stuck in standby. The standby light is flashing and so is the clock screen
My rca 5 disc changer stuck in standby
Posted on Apr 04, 2010
Stuck in standby
You can reset all to factory settings, which may help; unplug power, put back in switch on with power button. Then press together "tape", "CD" and the power button. You may need to reset the clock before it will work. If you need the manual, here is the link; http://pdf.crse.com/manuals/2048589112.pdf check page 26 for the reset if not clear - nothing else in there that seems to be related, but you may find something i missed. Hope this helps :)
Jul 01, 2007 | Sony CMT-CPX11 CD Shelf System
I have a gpx hm3817dtblk shelf system and i was wondering if you can get the alarm to play a cd instead of the radio or if you can do either one and how? Or does it even have an alarm?
The manual:
http://www.retrevo.com/support/GPX-HM3817DT-manual/id/1183ag710/t/2/
Page 6>>>>
Setting the Clock
a. Press the STANDBY button until the unit is in standby mode.
When the unit is in standby mode, the STANDBY button will be red.
b. Press the CLK ADJ. button. The time will begin to blink.
c. Press the HOUR and MINUTE buttons to adjust the hour and minute.
d. Press the CLK ADJ. button to set the adjusted time.
Setting the Alarm
b. Press the ALARM SET button. The time will begin to blink.
c. Press the FUNCTION button to seleect CD, Radio, AUX, or Buzzer.
For Buzzer mode, the display will not show any indication.
d. Press the HOUR and MINUTE buttons to adjust the hour and minute.
e. Press the ALARM SET button to set the adjusted alarm time.
An alarm clock icon will appear on the LCD Display when the alarm is set.
Jan 03, 2011 | GPX HM3817DTBLK Shelf System
Unit does not turn on or display time
do you mean a power surge, if so the surge may have overloaded the elctronics,=cooked ,so afraid is u/s
Jul 07, 2010 | Fisher SLIM-3010 Shelf System
How to set clock
Follow below procedures to set the clock..
1. Press CLOCK until the time flashes on the display (12-hour clock for RCA, 24-hour clock for Thomson).
2. Press TUNING UP or DOWN to set the hour and then press PRESET UP/ DOWN to shift to minute digits.
3. Press TUNING UP or DOWN to set the minute.
4. Press SET to save settings and STOP to quit setting.
Note: When system is ON, you can press CLOCK to
display the current time for about 2 seconds.
Regards,
Jeep Brainy
Sep 19, 2009 | RCA RS1285 CD Shelf System
Cannot set the time, need manual for our RCA RS2620 system
hold in the "clock" button until the hour flashes
use the forward & back buttons for the cd player to set the hour. (located just to the right of the equalizer" button)
once the hour is set, press the "clock" button until minutes are flashing.
use the forward & back buttons for the cd player to set the minute.
once done, press the "prog.set" button below the forward & back buttons
Dec 31, 2008 | RCA RS2620 CD Shelf System
RCA RS2640 Quit
Unit probably has defective component in standby circuit. Have serviced
Jan 15, 2008 | RCA RS2640 CD Shelf System
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
Can you tell me how to change the clock on my RS2652?
press and hold the "CLOCK" button until the time flashes, the using the << & >> buttons, adjust the hour, press "CLOCK" once more to select minutes. again, using << & >> to select time. press "PROG. SET" once. good luck
Nov 20, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
825 people viewed this question
 Grubhead
Grubhead
