Question about Samsung SyncMaster 204B 20.1" LCD Monitor
No Display on my Samsung 204B monitor
The monitor was working fine for 2 years. A couple of days ago it stopped working. The screen is blank with the power button blinking. i have exchanged the monitor with another which works, so the problem is definitely with the 204B. do you have any suggestions?
Do you know how the 3 year warranty works?
  • 6 more comments
  • Anonymous Dec 12, 2008
    All I can tell you at the moment is that I have exactly the same problem with a different Samsung Syncmaster model...711MP
  • schosche Dec 20, 2008
    I have the same problem , the power light is blinking and the monitor will not come on. Several weeks prior to this the monitor would flcker and then eventually come on. Now it doesn't work at all.
  • hhawbecker Dec 30, 2008
    I have the same problem, my monitor was working great for one year and then it just stopped. It started to flicker on and off for a few weeks and now it won't work at all. Any suggestions would be greatly appreciated. It sounds though like it may be a problem with the monitor.
  • pittsrusty Jan 05, 2009
    I have the same problem my 204b monitor is two years old and just quit working,but the power button blinks
  • todradford Jan 17, 2009
    Ditto. Have had monitor little over 2 years.
  • jazekid Feb 28, 2009
    I've replaced my monitor 2 times already. First the monitor backlight starts to fade and it goes dark and then eventually it will die. I am going to have to send in for replacement again.
  • chad970 Mar 13, 2009
    moniter just stoped working, screen is black
  • thomaswbutt May 01, 2009
    I have the same problem. After a few weeks of battling to get it on by lots of switching it off and on and unplugging and replugging, my monitor now just blinks it's little blue power light at me and stays black.
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Posted on Aug 21, 2009
Monitor is about 18 months old.
Was working perfectly until about 3 months ago.
Then started having trouble coming out of sleep mode.
Power cycling several times would normally recover it.
(using the hard switch on the back next to the power cord).
3 days ago, even this stopped working.
Now i just get the fast blinking led on the front. (faster than once per second, approximately twice per second).
The sad part is that this is probably some kind of internal power problem. The LCD panel ($$) is fine.
Posted on Jan 05, 2009
When I attempt to bring it back up, or turn it on,monitor screen stays black long time, then flickers, then slowly, ever so slowly, comes into view. Works ok at that point. Happening every time now, and...
The Samsung 204B monitor have a know issue with failing power supplies that cause the exact problem you are having. At first they are a little slow to display a picture and the more you keep using it the longer it takes for the display to come on. The repair is simple if you can solder. Here is a link to a site with additional information on this repair. http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ This Samsung 204B monitor is a great unit with a simple to solve issue. No need to trash a good unit.
I hope this helps, if so please rate our solution.
BuddyMc
Jul 04, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
SyncMaster 204B - when pc goes into blank screen mode (normal) the monitor does go black (normal). But when waking up PC the monitor just start flashing the screen extremely fast, progressing slower and...
Yes, The repair is simple, it requires changing out 5 capacitors. We have a full repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ We also have a parts kit available for $12 shipped.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Screen Resolution problem
Different video cards offer different ways to deal with a user's screen. ATI, and others, for instance, offer a "virtual desktop", which does what you're describing. You get to the settings that control this feature from the Personalize->Display Settings menu options. Here you'll also find the different resolutions your video adapter supports. If the 1600 x 1200 resolution is listed, then I would remove the existing driver for both the adapter and the monitor, and reboot the machine. On startup, Windows will most likely detect the "new" hardware (actually, your existing ones) and will go through the process of finding the appropriate drivers for your adapter. Good luck!
Jul 17, 2009 | Samsung SyncMaster 204B (Silver, Black)...
SyncMaster 204 Samsung monitor has no power
Have you tried to plug it in else where?
If you did and still same problem then from what you said I was hopping that it wouldn't be your problem, but you will need a new monitor.
Mark
Mar 29, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Unclear Display
Goto cotrol panel/display/settings and set the resolution to 640x480. Make your you are using the video driver from the manufactorer for your video card. Windows generic drivers do not work well for all monitors. When you get the proper video driver you can reset your resolution back to a higher setting.
Apr 28, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
1,155 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
