Question about Compaq Presario 5000 PC Desktop
Compac Presario DeskTop
The computer is less than 6 mo. old. We have had problems with getting it to open. Now it will not open at all. Just keeps scanning trying to open. It has Vista on it.
  • Francisco Cortes
    Francisco Cortes May 11, 2010
    what do you mean to open? if you're trying to open the case.. I suggest you DON'T as you may be voiding your warranty as the computer is still withing the first year (manufacture warranty).
    do you mean to start?..
    what do you mean scanning? are talking about a scanner??
    please refrase your question and make it as clear as possible.
  • 58 Answers
Systems usually come with a large amount of "startup" items - each of them takes up memory and slows down the computer; sometimes significantly. By performing the steps below, it does not remove the program from your computer; it merely keeps it from "pre-loading" when your computer starts up. Some things, such as your antivirus software, drivers and "easy button" type software that runs the extra buttons on a keyboard, for example, should not be removed from startup.
Go to Control Panel, turn on the Classic View and then go to Administrative Tools. Go into "System Configuration".
You will see several tabs: General, Boot, Services, Startup and Tools.
Click on the Startup tab.
You can choose to disable unnecessary programs but as I stated in the beginning, make sure you don't disable any important system components or drivers. If you are not sure which ones you can disable, it is better to consult someone knowledgeable with a list (the list is different on every computer) and let them help you.
If you know which programs you don't need to start when Windows starts, just uncheck the box on the left side of each program you want to disable. When you are finished, click OK.
A new window will appear and ask if you want to restart the computer. Go ahead and restart now.
After the reboot, you will see a balloon popup showing "Windows has blocked some startup programs".
In order to remove this, click the icon in the system tray and select "Run blocked program" and then click on System Configuration Utility. You will see another window with a warning, once again, that you have changed the way Windows starts. Select "Don't show this message or start System Configuration when Windows starts" and then click OK.
You may be extremely surprised at how much faster and more smooth your system will run without the extra load on your memory. If you would like to re-enable any of the items, just follow the same procedure, and place the checkmark back in the box for items you would like to re-enable for startup.
Posted on Dec 12, 2008
Keep losing wifi,must power down to get it to return. have a very strong signal. happens daily. my aries 11 is less than 6 mo old.
Get it repaired under warranty or try taking it back to the store you bought it from. You can try relocating it to a higher place in the room. The closer it is to the ceiling and in the center of the house, the better.
Jul 11, 2017 | Power Computers & Internet
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
My nephews compac presario 5000 desktop computer is in "power save mode" what is the cheapest way to fix this problem. Alan
Just reinstall Windows - free. If you can't do that then it's a hardware problem and you will have to find out what parts have failed (by testing each of them independently) and buy them.
Dec 24, 2010 | Compaq Presario 5000 PC Desktop
Unlock Bios Compac evo
On most PCs you can open the BIOS by hitting while the computer is booting: Del, F10, F2, Alt+Enter, F1. These are the most common but if they don't work just hit keep hitting your different "F" keys each time you boot one of them should open the BIOS. If the BIOS is password protected you'll need to either remove the BIOS/CMOS battery or short out the reset jumper on the motherboard.
Mar 27, 2010 | Compaq Presario 5000 PC Desktop
I have 2 compac evo d500 computers they keep on restarting everytime they load windows xp
repair xp installations, must be infected with similar virus or malware.
Regards
Feb 24, 2010 | Compaq Presario 5000 PC Desktop
Usb drive not accessible or write protected error
Once you eliminated it just being a particular USB port (they go defective with wear), consider that your WinXP or whatever might be patched ...at all, basically... on that machine. It's rare that there's an OS issue, but Sandisk U3 is less readable on older Linux. Since you have cited neither USB drive model nor the OS you're using, that's the news; update the OS! Get Syllable or something decent, maybe.
Aug 06, 2009 | HP Compaq Presario SR1575CL (PX808AA) PC...
JAVA multiple programs on disk
no you don't. Just keep the most recent version.
May 04, 2008 | Sun -115H Computer Speakers
Compaq Presario 5000 PC Desktop Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
