Question about EuroTech 24 in. EDW154E Built-in Dishwasher
I have a Eurotech EDW154E dishwasher. I keep getting an error code 4. The previous owners said there is a way to reset the machine. Any ideas?
    Problem Solver:
  • 6 Answers
Eurotech Dishwashers are notorious for the E1 and E4 faults. The problem is with the solenoid they use for filling the dishwasher. The problem is something called the "Venturi Effect". The Venturi Effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The fluid velocity must increase through the constriction to satisfy the equation of continuity. while its pressure must decrease due to conservation of energy. The gain in kinetic energy is balanced by a drop in pressure or a pressure gradient force. I know, a lot of big words. To put it simply, the orifice within the solenoid is smaller than the inlets and outlets. Even more simply put: Not enough water is getting into the dishwasher. It appears that Eurotech isn't like a simple washing machine that senses fluid level and then shuts off the solenoid. It seems that it's on a simple timer. Turn on the solenoid for X time then turn it off. If not enough water, send fault code. It's a design flaw and I'm not certain there are many ways around it. Just make certain that you have a good water feed to the dishwasher (no kinks, valve on completley etc.). One thing you may try is reducing the feed pressure (i.e. slightly turn down the water valve supply to the dishwasher). Doing so may diminish the venturi effect by equalizing inlet pressure, hence allowing more water into the dishwasher. It's worth a try.
Posted on Feb 08, 2009
What does the error code ER5 for a EDW154E Eurotech D/W mean?
e5 error is drain error. need to check all drain related items.
drain pump, drain hose, and of course garbage disposal knock out.
Jun 06, 2014 | EuroTech 24 in. EDW154E Built-in...
Where do I place the silverware rack in the Eurotech ndishwasher
Once you load it with handles down and so the tableware won't nest too much, place it anywhere it will fit and not be blocked from getting a good spraying from the water arm that spins under the rack.
Sep 15, 2012 | EuroTech 24 in. EDW154E Built-in...
Where is the rack for the silverware to be placed?
Anywhere it will fit and still be hit by water from below.
Error message erro1 on eurotech dishwasher
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jul 28, 2010 | EuroTech 24 in. EDW154E Built-in...
Looking for a water inlet valve for a eurotech edw154e
You can try to replace the solenoid with another dishwasher solenoid, but be prepared for some of what we call "backyard mechanics" :>) It can be done, and it will work, but it may not look pretty.
Dec 17, 2008 | EuroTech 24 in. EDW154E Built-in...
Dishwasher
Could also be a water temp problem. If the water isn't hot enough the dishwasher will run longer as it has to heat the water. This could be your water heater turned down too low or the heating element in the dishwasher isn't working properly.
May 14, 2008 | EuroTech 24 in. EDW154E Built-in...
Error messages on a EuroTech EDW154E dishwasher??
Eurotech Dishwashers are notorious for the E1 and E4 faults. The problem is with the solenoid they use for filling the dishwasher. The problem is something called the "Venturi Effect". The Venturi effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The fluid velocity must increase through the constriction to satisfy the equation of continuity. while its pressure must decrease due to conservation of energy. The gain in kinetic energy is balanced by a drop in pressure or a pressure gradient force. I know, a lot of big words. To put it simply, the orifice within the solenoid is smaller than the inlets and outlets. Even more simply put: Not enough water is getting into the dishwasher. It's a design flaw and I'm not certain there are many ways around it. Just make certain that you have a good water feed to the dishwasher (no kinks, valve on completley etc.). One thing you may try is reducing the feed pressure (i.e. slightly turn down the water valve supply to the dishwasher). Doing so may diminish the venturi effect by equalizing inlet pressure. It's worth a try.
Dec 30, 2007 | EuroTech 24 in. EDW154E Built-in...
DE73 A04 Error code
you may have a bad heating element..or temperature sensor the water temperture is not getting hot enough to let the dishwasher run. you my reset it and try running the water in the sink until it reaches hot ... then try stating the dishwasher...let me know if this helps
Aug 28, 2007 | Indesit 24 in. DE73 Evolution...
EuroTech 24 in. EDW154E Built-in Dishwasher Logo
466 people viewed this question
Top EuroTech Dishwashers Experts
Tony Houde
Tony Houde
Tom Chichester
Dave Glabb
Are you an EuroTech Dishwasher Expert? Answer questions, earn points and help others
