Question about LG RUMOR Cellular Phone
The two side buttons ( send button ) stay lit up as red
They won't go away. even if i charge my phone up all the way
    Brigadier General:
  • 7,752 Answers
Try resetting the phone the riddim lights should be set back to it's default
Posted on Dec 27, 2008
My PS3 headset won't charge it stays lit for 3
If there was no change using a new charger, I would suspect the battery is shot
Apr 23, 2013 | Radio Communications
My sony xperia T will not charge
Success story. Disclaimer I haven't notice any damage or
loss of data, However I take no responsibility for any damage or loss of data
that may occur.
My girlfriend has a xperia T and did let it go flat, since
then it didn't appear to charge or switched on.
I had tried allsorts suggested on various websites such as
plugging charger in and out a few times, leaving in charger for 24 hr, plugging
into laptop, and trying to power up with power button and volume up. Red light
sometimes lighting up or flashing but not staying lit.
After playing around with all of the above methods, I
noticed if I kept my finger on power while plugging into the charger or laptop
the red led stayed on until I let go. So I tied an elastic band around the
phone on the power button, then I plugged in the charger, unplugging it,
plugging in again with volume up pressed until I had the red led lit. Not sure
of which combination I did but just when the led was lit (not flashing). I left
it for a few hours while it was plugged in with the elastic band keeping
pressure on the power button. Came back to it and found the phone on and
battery at 100%.
Hope this helps some of you
Mar 29, 2013 | Cell Phones
I have VIBE bluetooth keyboard for iPad mini ( VE 1089) and can't find ON switch
yes the red charge light will only stay lit for just a little bit... then turn it on by pressing down above the words written "charge". You should be pressing and holding down on a dial with three semi circles above it (as szuravic stated). Press and hold down until you get the bluetooth and power button lit on blue. Then go to your settings and bluetooth.... "bluetooth keyboard" should pop up. Click on it and then it will ask you to enter a 4 digit code on your keyboard followed by the return key. Soon after you should be "connected". If you are fully charged (first time plugged in should be 12 hours.. then after 4 hours) then you can unplug. Hope that's helpful!!
Feb 05, 2013 | Apple Ipad I-pad
Plantronics cs50 red power light is not lit
Sorry to hear about your bad luck there. If a hard reset does not work and its not simply the power button is not correctly aligned (try fiddling the pressure up and down if it is loose) then it's likely the device has failed. Even though it's survived other power outages it's still entirely possible the most recent one has caused this failure. I've seen failure of electronics from operating on unstable voltages from solar panels and less than perfect inverter systems and it's always the case that "it's been working fine up until now!"
Mar 01, 2017 | Plantronics Radio Communications
How to store numbers in memory of big button 100 phone
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Apr 20, 2012 | Big Button TV Universal Remote
Red Message List stays lit solid even when there are no messages.
No, it stays lit because there *are* messages, just not voice mail messages. Press the MESSAGE button and look at the display. Look at what's above soft key #3. If you don't need the information in the first line, use the CLEAR key to erase it.
Carl
Apr 04, 2011 | Panasonic KXDT343 Phone
My rowenta iron which is about 4-5 years old starts blinking the red on-off button after only 2-3 minutes of use. Also the orange button will not stay lit. What is the problem? The red on-off button does...
your iron has a thermostat fault its this thermostat thats cutting in and out that puts the red light on it could be fixed but that wont be a cheap fix best bet is to buy a new iron as that would work out cheaper
Sep 11, 2010 | Rowenta DX6700 Iron
I plugged my W890i in to charge and it did the usual buzz, red light switch off and just showed a lit up/black screen (with the red light on the back). Taking the battery out and putting it back in didn't...
it is not totaled, it sounds like corrupt phone software issue which is an easy fix and can be done for free (I see you breathing a sigh of relief when i said that lol), the way i would fix it is this:
read this tutorial http://forums.se-nse.net/topic/39748-tutorial-flashing-a2-phones-with-a2uploader/
(side note: if you flash with generic software you can debrand the phone - something phone shops charge around £30 to do and will speed the phone up slightly aswell as loosing all the **** that networks like putting on every handset)
when done with that google a programme called aerix if you want to unlock it aswell (also free)
Oct 21, 2009 | Sony Ericsson W890i Cellular Phone
Old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Aug 05, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Water heater will not stay lit even after replacing thermal coupl
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
Jul 16, 2009 | Kenmore Dryers
LG RUMOR Cellular Phone Logo
144 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
