Question about Roper RAS6233KQ Top Load Washer
Can't get Dryer Belt on Kenmore Dryer
The belt on my Electric Kenmore Special Edition, Heavy Duty Dryer went. The new one came today, however, all the diagrams do not seem to match my dryer. They all appear to have a staggered pully system and I can only find one area where the belt winds around one pully which does not take the slack out of the belt. I took photos but don't know how to post them here.
Thanks
    Problem Solver:
  • 8 Answers
Not sure if your dryer is the same, but here's a diagram that may help.
Posted on Jan 09, 2009
  • 5,911 Answers
Have you tried looking at repairclinic.com? Click on the "Repair Help" link followed by the "Dryer Belt Diagrams" under the "Special Features" section. If your dryer is a Kenmore, drawings H, B, or K should match your belt configuration. The diagram you need is based upon the first three digits of your model number, and whether or not the back panel of the dryer is removable. I hope this may help you. Let me know if you still require assistance.
Posted on Dec 12, 2008
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
My dryer heats up but the drum does not rotate im going to try and see if the belt has broken any other suggestions?
Most likely belt has broken. Once in awhile, the belt will work its way off if you had weird loads like shoes or something. The other likely possibility is the motor. Motors are very simple to replace as well.
Jan 13, 2014 | Dryers
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Part number 8066065 kenmore heavy duty super capacity dryer electric belt for dryer tub
Hi mousessugar2...
Go to the following webpage and order your belt...it has changed numbers
It is no longer part number 8066065...It is now a Part number 341241.
Please take time to rate me thumbs up.
http://www.appliancecarestore.net/replacement-for-kenmore-amp-whirlpool-dryer-belt-341241.html
Sep 24, 2011 | Kenmore 63942 Dryer
Belt worn out - need to find the model number: amana heavy duty gas dryer - limited edition
you gave the model number it's NDE6800AYW,the belt part number is 33002535 and it's around 25 bucks
Jul 31, 2010 | Amana NDE6800AYW Electric Dryer
Dryer Belt
your model number is inside the dryer door,you can go to your local appliance part store or to sears.com or repair .com or ebay to buy one-mike
Jun 22, 2009 | Kenmore Dryers
Can't get drum belt on Kenmore dryer
Generally belt comes around drum then around pulley tensioner and then back to motor pulley in a zigzag fashion
May 06, 2017 | Dryers
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Roper RAS6233KQ Top Load Washer Logo
280 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
