Question about Breville ESP8XL Espresso Machine
No water I just bought this machine today, and i cannot get any water to come through the machine at all. It gets hot, but no water or steam. it's not being sucked up into filter at all. any ideas?
  • 4 more comments
  • roxsailors Dec 13, 2008
    There is no water leaving the tank. The pump makes a klunk klunk sound, no steam, no warer.
  • Anonymous Dec 16, 2008
    I have the same problem. If only there were a solution. Breville hasn't responded to my email. Sigh.
  • hamsterlover Dec 28, 2008
    Yes, I have the exact same issue! I have NO idea what to do! HELP.
  • Anonymous Mar 21, 2009
    No water flow and I've pushed the basket down all the way...back to the store <>
  • Jay Chinook Mar 22, 2009
    Water stopped flowing through coffee basket, after months of great coffee.
  • aversano May 08, 2009
    I got the machine today. makes a lot of noise but no water is coming out.
I had the same exact problem -- the water basket simply needs to be pushed down harder.
Posted on Jan 07, 2009
Four month old coffee machine, little used, not producing hot water or steam, the coffee regular is tepid at best
If your four month old coffee machine is not working as expected, you should claim your warranty where you bought it so it should be repaired.
Apr 28, 2015 | Coffee Makers & Espresso Machines
I need to descale my machine, now the screen says descale and "purge" and nothing happens when I press hot water on OR want to let steam out
There is a blockage in the steam/hot water circuit . Try poking the end of the steam tip on wand with a paper clip. Make sure turn the hot water on by pressing the hot water button and turning the steam wand.
Apr 08, 2015 | Saeco Magic Comfort Plus Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
My steam/hot water arm fell out along with no steam
Easiest way to get to it, remove the 2 screws in the bean hopper, and remove the hopper, there are a few screws under the water tank, this should give you access to the machine top. Check the end of the steam wand it might be blocked use a paper clip to clear it out. Run it under the faucet to make suree it is clear. Check the microswitch that is connected to the steam valve, It can be seen when you turn the knob to open the steam/hot water valve, make sure it is not stuck in the on position.
Dec 06, 2009 | Saeco Vienna Espresso Machine
Gaggia Titanium, makes hot water but no steam
Push in on the steam knob, if that works, then the steam valve assembly needs to be replaced, tell the Tech where you bought the machine that you need to get the new stainless steel valve.
Jun 18, 2009 | Gaggia Titanium Espresso Machine
Stuck
I read about others having the problem, and used some of their suggestions. What worked was to repeatedly hit the hot water button, open the valve, then close it when it said to. After several repetitions it worked. Since then, I have followed steaming with running about 4 ounces of hot water through, so their won't be air in the line. So far, so good--** problems today.
Mar 08, 2008 | Gaggia Titanium Espresso Machine
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
CLogged Titanium
Love to go over the problem with you. Give me a call at 866-408-9438.
Ask for john.
Cerini Coffee Services
Authorized Gaggia Service center
Oct 14, 2007 | Gaggia Titanium Espresso Machine
Breville ESP8XL Espresso Machine Logo
328 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Steve
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
