Question about Air Tools & Compressors
Need valve lash specifications for Model 6076AF-00 (L)
Need tune up specifications or valve lash specifications to
adjust the rack
Dear Sir or Madam, We have the pleasure of contacting with you today. We get your name and email address in internet and now would like to have a brief introduction about our company for your understanding. We are professional valves manufacturers and exporters in China, our main conditions are as follows: 1.Product: ball valves, gate valves, globe valves, check valves, etc. 2.Standard: API, DIN, JIS, GB. 3.Material: WCB, LCB, CF8 304, CF8M 316, CF3 304L, CF3M 316L, WC1, WC6, WC9, CN7M and so on. Should any of these items be of interest to you, pls feel free to contact with us or visit our website:, we will be happy to give you details. Look forward to your specific enquiries and hope to have the opportunity to work together with you in the future.
Best Regards
TEL: 86-577-67952090
FAX: 86-577-67981377
Posted on Apr 10, 2009
Need to know valve adjustment for 2012 ram 3500 turbo deisel and do you have to adjust the exaust valve n if so what is the spe. Tk. Joey
The 24-valve overhead system is a "low-maintenance"
design. Routine adjustments are no longer
necessary, however, measurement should still take
place when trouble-shooting performance problems,
or upon completion of a repair that includes removal
and installation of the valve train components or
(1) Disconnect battery negative cables.
(2) Remove cylinder head cover (Refer to 9 -
(3) Using the crankshaft barring tool #7471-B,
rotate crankshaft to align damper TDC mark to
12:00 o'clock position.
(a) If both number one cylinder rocker levers are
loose, continue to next step.
(b) If both number one clylinder rocker levers
are not loose, rotate crankshaft 360 degrees.
(4) With the engine in this position, valve lash can
be measured at the following rocker arms: INTAKE
1-2-4 / EXHAUST 1-3-5. Measure the valve lash by
inserting a feeler gauge between the rocker arm
socket and crosshead (Fig. 32). Refer to VALVE
LASH LIMIT CHART for the correct specifications. If
the measurement falls within the limits, adjustment/
resetting is not necessary. If measurement
finds the lash outside of the limits, adjustment/resetting
is required.
0.152 mm ( 0.006 in.)
0.381 mm (0.015 in.)
0.762 mm (0.030 in.)
If measured valve lash falls within these
specifications, no adjustment/reset is necessary.
Engine operation within these ranges has no adverse
affect on performance, emissions, fuel economy or
level of engine noise.
(5) If adjustment/resetting is required, loosen the
lock nut on rocker arms and turn the adjusting screw
until the desired lash is obtained:
² INTAKE 0.254 mm (0.010 in.)
² EXHAUST 0.508 mm (0.020 in.) Tighten the
lock nut to 24 Nm (18 ft. lbs.) and re-check the valve
(6) Using the crankshaft barring tool, rotate the
crankshaft one revolution (360°) to align the
damper TDC mark to the 12 o'clock position.
(7) With the engine in this position, valve lash can
be measured at the remaining rocker arms: INTAKE
3-5-6 / EXHAUST 2-4-6. Use the same method as
above for determining whether adjustment is necessary,
and adjust those that are found to be outside of
the limits.
(8) Install the cylinder head cover (Refer to 9 -
(9) Connect the battery negative cables.
Jun 14, 2016 | Cars & Trucks
Need valve lash specs for 1980 suzuki dr400
Suzuki DR400S - Motorcycle Specs
1980. Engine. Air cooled, four stroke, single cylinder, SOHC, 2 valves per cylinder ....Valve adjustment can be done without a feeler gauge and the CDI has ..
Dr400 valve adjustment 1 - YouTube
? 2:08
Nov 19, 2010 - Uploaded by obtrailriders
Dr400 valve adjustment 1. ... Suzuki DRZ 400 Valves clearance check \ sprawdzanie luzu zaworowego PART 2 ...
Nov 01, 2015 | Suzuki Cars & Trucks
What is the manufactures preset adjustment on the valve lash
Almost all engines now have hydraulic lifters. Many mechanics, and those of us without the detailed specifications, set the valve lash while the engine is running. Back off the adjustment on the rocker until you hear a clicking sound. snug it up until the clicking stops and NO MORE.
You may splash some oil while doing this, but I've tuned a number of race engines this way and it works.
Mar 16, 2015 | Cars & Trucks
What is the valve clearance on 3.0 flex fuel
Valve lash adjustment, is mostly all hydraulic with no adjustments, if you are experiencing some sore of noise for lifters try desludging the engine using aa motor treatment. Follow all directions. When I rebuilt heads most lash adjustments are 8 to 10 thousandths for intake and 10 to 12 thousandths for exhaust. Also timing components can also sound like lifters, in some cases a bad waterpump causes weird sounds too.. please try to ask more specific questions.
Feb 28, 2015 | Cars & Trucks
How do I set the valve timing on my 2007 Astra 1.3 cdti when there is no timing hole on the bell housing
If therewere a hole to view as on other cars you would be setting "Ignition " timing Valve timing is done at the gears one on the crank & one on the cam shaft ,if so there is mark on each gear ,You should rfer to specific specs. in a book for that model & year.. You have to open the case cover for that. Are you refering to setting the "valve lash" ? If so you need to refer to "valve clearence or valve lash" specifications chart, If adjustable. Either way always check a manual for specific needs.
Mr. Red
Dec 16, 2013 | 1994 - 2001 Lexus ES300 Engine Timing Belt...
How do I adjust the rocker arm bolts for the valve lash on a 1985 Nissan 720 pick up Z24 engine
Guys he has a Z24, Not KA24, Z24 for one, Is carbed and has older lifters and valves. They need to be tuned to spec within a certain specific limit and the cams must be rotated in certain positions when doing different valves, etc... Shouldnt take very long normally and its not a hard process but if you have a tick, you really should get it checked out. Btw, the Z24 engine's idle isnt controlled by ecu at all or else the carb wouldnt need an idle adjustment screw.
May 27, 2012 | 1985 Nissan Pickup
Overhead valves making noise like they need ajusting
Valve Lash ADJUSTMENT 1.6L Engines NOTE: Measure valve clearance with the engine cold.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the valve cover.
  3. Set the engine to Top Dead Center (TDC) of the compression stroke for the cylinder to be adjusted.
  4. Check the valve clearance. The valve clearance specifications are as follows:
    • Intake valves: 0.005-0.007 inches (0.13-0.17mm)
    • Exhaust valves: 0.005-0.007 inches (0.13-0.17mm)
  5. After adjustment, tighten the locknuts to 11-14 ft. lbs. (15-19 Nm).
  6. Repeat for each valve to be adjusted.
1.8L, 2.0L and 2.5L Engines The 1.8L, 2.0L and 2.5L engines utilize automatic hydraulic lash adjusters to maintain proper valve lash at all times. Periodic valve lash inspection and adjustment is not necessary or possible. prev.gif next.gif
Sep 14, 2010 | 2000 Chevrolet Tracker
Need valve lash adjustmentstats
Briggs & Stratton engines have a designated clearance adjustment that is dependent upon the MODEL number of the engine and are different between intake and exhaust valves. The measurements vary between .002 and .019 depending on your model number and which valve you are adjusting. If you want to post a MODEL AND TYPE I can be more specific with an answer
Oct 17, 2009 | Briggs & Stratton Garden
Top end noise Valve clearance
Top-end tune? This engine has oil-pressure-fed valve lash adjusters. There are some snake oils (engine oil additives) out there that claim to be able to free-up lifters and lash-adjusters, and you may have some success with following their instructions. After that, I would be checking what grade of oil you should be using in you climate and doing regular (possibly more frequent) oil changes.
Apr 29, 2009 | 1999 Suzuki Vitara
Air Tools & Compressors Logo
186 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
