Question about Nikko RC Hummer H2 Off Road Truck
Hummer truck will not go foward
We have a hummer remote control truck that goes in reverse, but does not go foward.  We have replaced all the batteries, but still no luck.
  • 49 Answers
The maninboard of the nikko car is broken you may need to change it or look for it at ebay or search in a second hand store and find a cheap card with the same tipe of baterrie and model to buy it for replacement parts
Posted on Jun 17, 2009
I have a 1973, 65hp 650 mercury , and it is in foward and in neutral, or reverse position it's still in foward , , what could the problem be ? Thank You , Tommy
-Check if the forward - Neutral - Reverse 'commando' works in the motor cowling.
-If OK, check the movement of the shift shaft just above the drive.
The shaft must turn left - right when acting the remote control.
-If it all moves, the problem is IN the gearbox... Then you'll need some special tools and knowledge.
Aug 29, 2016 | Boating
I replaced a bearing and seals in my john deere 185 hydro and put new belt on. Now when I put it in foward it goes in reverse and reverse when it will go forward. What did I do wrong.
Sounds like the lever on top of the transaxle where the rod hooks into was put back on wrong. Take the rod loose, take the nut off , lift the control lever up and rotate it half a turn and put it back down, replace nut and rod and try it.This would reverse the action of the push and pull of the rod.
May 10, 2016 | John Deere Garden
What could be wrong with my 2006 Hummer h2 that has no foward or reverse gear sand when in Park its still in nuetral?
check the linkage,... look at shifter cable bushing most likely missing, or rotten. there is an aftermarket bushing by Dorman part 14055 about 12 bucks or a new cable around 65.00 plus2 hours labor. Also bushing fix has something on Ebay 25.00 an ez install bushing. I put new cable on mine and repaired old cable w/ new bushings for next time. Very common problem Good luck all
Jun 14, 2014 | Hummer H2 Cars & Trucks
Looking for a wiring diagram for 12 Volt Remote Control Ride On H2 Humm er Jeep Truck. I bought used, but put on charger and nothing works, dead as a door nail. Thinking maybe a loose wire or possible...
Look under the hood and there used to be only a few wires but the main two that runs the battery connects to a junction box under all the fancy engine stuff that you can remove and then you can see all the wiring and what goes where & to what . Usually black & red wires trace them out its easy. You have to replace the battery in the toy hummer its almost as cheap to put a lawn mower battery or one that is supposed to be recharged off and on , like a marine battery more power. I used a speaker wire to put the bigger battery in the passenger floor of the corvette my grand kids have.
Aug 12, 2013 | Trend Times Toys 12 Volt Remote Control...
John deer gator goes foward in the reverse position and reverse in the foward positions.
you just need to switch the polarity on the motors swap the two wires around
Feb 25, 2011 | Peg Perego John Deere Gator HPX
I have a remote control truck from radio shack. Well I had to install a new motherboard from a messed up r/c. (same truck) It worked for maybe 2 minutes then I noticed one of the wires on the motherboard...
Hi, Looks like the one you soldered is not supposed to be there.
Check it again and look for the part that might the original soldered point for that wire.
Hope that solve everything!
Dec 14, 2010 | Hummer REMOTE CONTROL HUMMER H2 RC CAR...
1998 ford van e-250 noparking no reverse guess my tranny is gone
Sorry but thats exactly what it is. You may check local salvage yards for a replacement to save $.
Good luck. Dont forget to rate.
Mar 11, 2009 | 1991 Ford Econoline
Tranny goes in reverse but wont go into foward gears
how many miles on trans? does fluid smell burnt?350 turbos are good tranneys but they do go bad. in my experance its reverse that goes out first on thies transmissions but thats not saying that it does not happen the other way either. my best guess is you need a rebuild. when you say it tries to move in forward gear that tells me that the clutches are shot. 350 turbos are worth rebuilding. its up to you.
Jan 07, 2009 | 1991 Nissan Sentra 2 Door
Nikko RC Hummer H2 Off Road Truck Logo
543 people viewed this question
Top Nikko Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Nikko Toy Expert? Answer questions, earn points and help others
