Question about Independent Inc. Laramie Wall Model - LARA Kitchen Hood
New range hood whistles on high
We have a Laramie 1200 cfm hood installed and it has a whistling noise when it is on high.  Our installer has no clue and has given up. His only thoughts is well do not use it on high.  The duct run is about 16 feet straight up after it comes through the wall.  Duct is 8 inch diamter and there are not any restrictions.
Please call Diana Vincent at 775-358-0263... or Jeff Bilyeu at the same number...
THEY WILL HAVE AN ANSWER!!!!
Thank you,
Lauren Kilmer
Posted on Apr 21, 2009
2011 Avalon high pitched whistle
I had that , and it was the transmission low on oil. Hope this helps.
Mar 20, 2014 | Toyota Avalon Cars & Trucks
Whistling noise when cooling on Kenmore built in oven model #790.48783900
These types of ovens are complex to troubleshoot and repair. I would contact an appliance tech.
May 23, 2012 | Ovens
Whistling sound form tweeters
The unit is picking up noise from the electrical system of the vehicle--power is either connected to the wrong place or a noise filter needs to be inserted at the voltage source for this equipment.
Apr 23, 2012 | Infinity Speakers Infinity Reference 1031t...
I have a 2004 pontiac grand am and it is making a whistle sound when I drive what is wrong?
It whistles because it does not know the words. Common experience tells us that whistling comes from sucking or blowing air or other gas, not a liquid, through an orifice. Lots of orifices on a car so start by having someone listen under the hood, after opening it, as it idles and even with some revving up and down a bit. Some clue may be given as to the location of the whistle.
If you look closely under the hood you will see many small diameter hoses, usually black, which transfer engine vacuum hither and yon to do work or throw switches as the car goes about its business. Following each of these hoses to their ends and making sure they are still connected could lead you to a whistler.
There is a large wide black belt under the hood called a serpentine belt, these have been known to screech as they age and/or become loose. If the whistle noise is actually a screech, then I think you could use a squirt gun to spray some water on it as it spins and if the noise briefly goes away until the water dries, you may cure your whistle with a new belt.
Someone who knows what they are doing is most likely going to have to put their eyes and hands on the car to figure this out.
Sep 14, 2011 | 2004 Pontiac Grand Am
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
Yesterday I had my heater converted fro LP to Natural gas (technician replaced orifice). Now heater makes loud whistling sound when burner is on. Stop making noise when heater is turned off and only blower...
The wrong orifice was installed. Sta-Rite changed their blower configuration 3 years ago. Heaters older than that have a flat orifice that works with the older style blowers. Newer heaters are equipped with a tapered orifice. Mixing a flat with a new blower causes whistling. Mixing a tapered with an old blower causes whistling. Good luck!
Nov 17, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
1993 Lincoln Continental v6 3.8L- whistling noise under the hood
if it's not running bad, it may be a simple crack in a pcv line, or a loose hose(vaccum). should be simple to fix.
Aug 29, 2009 | 1994 Lincoln Town Car
Whistling noise when accelerating
you most likely have an aftermarket radio installed
the noise you hear is engine noise, if yo turn your radio off it will go away
this can be fixed by either getting better wiring for your aftermarket radio or by installing a noise filter, you can purchase that at most big electronic stores
Jun 23, 2009 | 2002 Acura 3.2TL
Whistling noise on earpiece when on a call.Not all the time.
this can be caused by a few things, depending on the type of phone and where it is....if the phone has a built in amplifier, the whistling could be caused by acoustic feedback due to the volume level being set too high, also your phone could be picking up some stray frequencies from somewhere, eg flourescent lights, or radio frequencies, a hearing aid, or there could even be fault on the phone line.... sorry to seem so vague, but without more specific information were fishing for clues.
Jan 16, 2008 | Lands Phones
Kitchen Ranges Logo
494 people viewed this question
Top Independent Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Independent Kitchen Range Expert? Answer questions, earn points and help others
