Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Wash stops med cycle.
The washer stops during the wash cycle and there is setting water. The only thing we have to do at this time start it up again is "wiggle" the knob around. After we "wiggle" the knob the cycle continues as normal. It only stops in one spot and the same spot every time. Would this be a quick fix?
    Problem Solver:
  • 7 Answers
Should be check the knob itself to see if it cracked or busted on the outside if not probably the inside of it is cracked i would just replace the knob
Posted on Apr 16, 2007
My model # is LSR8233jqo. I believe I am having a problem ith the timer unit. Wash cycle starts after setting timer and runs for a while then stops mid wash usually just before the spin cycle. If I...
o.k test the a) water supply cold. read your instr. manual some model during the cycles coming cold water other hot water, read for is acting abnormally.
b) TESt the timer see the diagram> tight any wires connector loose or corrosion, or dirty.
see the w.diagram how the timer control any function of the washer.
God bless you
Jul 18, 2012 | Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
GE wprb8050d0ww washer
if it fills but not wash at all suspect the pressure switch its the switch where you select the water fill small med large behind that switch will be a dome looking piece with a vinyl hose connected to it try spin drain first if all that works replace the dome switch
Jun 05, 2008 | GE WPRB8050D Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
"Check Water Tap" error
rinse valve possibly open circuit or external water pressure low
Feb 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
