Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Freezer not working
Frigidaire 14 cu ft upright freezer not working. Don't know if door was left open. or if it just **** the bed. I noticed it was thermally protected. Is there a reset for this. Power to plug. Nothing. No humming, buzzing, clicking, light. Nothing. Freezer only ~8 years old or so. Removed relay unit from compressor and had Frig dealer check. OK. He said to give the temp controller a rap. No good. disconnected the three leads from temp controller and checked for continuity . All combinations I tried indicated controller was working. Has a red, blue, and black lead. Not sure which leads to connect to "hot wire", to bypass temp controller.
  • rp_suarez Jan 12, 2009
    it won't freerze
  • Anonymous Feb 17, 2009
    We unplugged our freezer to defrost it and when I plugged it back in it just doesn't work. It feels pretty cold on the outside, somewhat cool on the inside but isn't freezing.It is not making any noise at all. It's not the temperature control or power cord. I didn't know it had a reset button however. Where is this button if it exists?
    My freezer is also an upright frigidaire about 8 yrs old .
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Posted on Dec 12, 2008
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Control panel on the front of the door on my Kenmore upright freezer show an Sb. Can't get it to do anything else!!
This code represents a malfunction. Call frigidaire and find out what that code means. Your manual should tell you as we'll.
Feb 04, 2013 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezer not cold enough and fan doesn't blow.
if door was left open for extended period of time it has probably iced up around the evaporator fan, try to defrost around fan area using a hair dryer
Jul 28, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I want to know if the freezer Frigidaire has a defrosting clock
I wait a few hours and I turned it on, I wait again all night and it is getting it´s temperature. Thanks.
Sep 06, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Cu feet of Frigidaire Freezer modelffu14fc4cw1
according to your model number it is a 14 cu ft.  thx peyton
Jan 29, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
445 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
