Question about Sanyo EM-W3000W 1000 Watts Microwave Oven
Sanyo EM S667W 1000W 240V Microwave.
Neither turntable motor(TM) or cooling fan (CM) work.
The light (Not blown) does not work.
Oven heats as normal.
Sometimes cuts out during heating (Thermal Overload ?), if left power will return.
Schematic shows LIGHT,TM and CM in parallel connected to live rail after latch switch then to main relay
  • Sanyo Master
  • 9,098 Answers
Please do not operate the microwave (other than short bursts when testing) until the cooling fan is working again.
Otherwise, the magnetron will be destroyed, and that's expensive.
When the magnetron overheats (since the cooling fan is not working) the magnetron thermostat opens up to kill power and protect the magnetron until it cools back down again.
Chances are you have a bad connection, bad relay, or bad component driving the relay on the control circuit board.
If you will scan (at 300dpi if possible) the schematic, and e-mail it to me, along with clear digital photos of both sides of the board, I can probably help you get this fixed.
Feel free to contact me directly (and please remind me of your full model number).
William E. Miller
Posted on Dec 15, 2008
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ... > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
2 difrent microwave problems
is the motor with the fan on it working,thats most licklely the problem
Jul 06, 2010 | Sanyo EM-C1800 Microwave Oven
Microwave will no longer heat. Model #MA-1000W
So we can help you, please post a NEW question, and please include your model number MA-1000Was well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | Goldstar MA-1011 Microwave Oven
Light comes on and turntable moves but not cooking Model EM-G4775S 900 watts
Fuse blown? Needs to make high voltage for the magnetron. A blown fuse usually means trouble in the high voltage system (a shorted HV diode or maybe a bad stirrer [metal fan-like device] bearing which is located just above the interior case under the waveguide assembly). If suspect, replace the stirrer as a unit. If fuse looks ok, maybe bad door interlock switch or not being operated by door closure.
Aug 03, 2009 | Sanyo Microwave Microwave Oven
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Sanyo EM-W3000W 1000 Watts Microwave Oven Logo
279 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
