Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Won't start I was Sweeping & the Blanket Cornor got caught. Now the sweeper won't start
  • 107 Answers
Did you verify that the switch did not get moved to BARE FLOOR rather than CARPET. If it is not on CARPET the brush will not spin.
Posted on Dec 12, 2008
Keeps stopping even though I have taken it apart and checked for blockages. +
Are you sure your wall charger is working ok? You might just have a bad battery pack in the sweeper if your charger is working. Do you have a friend who knows electronics and has a voltmeter?
If so, have them check the voltage output of the charger at the plug that goes into the sweeper. Verify that the charger is indeed working ok. Then you will need to check the voltage on the battery pack inside the sweeper to see if your battery is good and holding a charge. A mechanical blockage could be something caught in the vacuum fan blade. You should be able to hold the main part of the sweeper up to your ear so you can hear and then pull the sweeper trigger and see if you can hear the motor try to start. Nothing happening may mean a dead battery pack. Regards, Dennis
Aug 15, 2015 | Dyson DC44 Animal Cordless Vacuum Handheld...
Sounds funny
like what.. a whistle? a sucking sound like a gasket not seated..
Mar 06, 2014 | Rainbow Vacuums
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The sweeper attachement went "dead." What could be
more than likely the overload or reset button has been tripped within the powerhead.
Press the red button or the square button on the left side top of the unit, more than likely it is the red one, and it should start up for you again.
Good luck,
Mark
Nov 09, 2010 | Kenmore Whispertone 23312 Bagged Canister...
My dyson animal sweeper just stopped running
Take it to your local vac shop and let them diagnose it. You are within warranty so if it is clogged warranty will not cover that, but everything else warranty will cover.
Jun 11, 2017 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dirt Devil M084600 Dynamite
If it is only 2 months old, then it is under warranty, take it in for warranty repair. There may be a circuit breaker on it, usually on the back at the bottom, it there is, push it to see if it has tripped.
Feb 25, 2008 | Dirt Devil M084600 Dynamite Bagless...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
110 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
