Question about 4D Scroll Track Finger Mouse Handheld USB Version MODEL FDM-G51 (FN4DUSB)
My finger mouse works just not the scroll feature
I have a gateway laptop and the finger mouse works but the scroll feature has stopped working can anyone tell me how to fix this?
  • 120 Answers
Check the scroll settings in Control Panel. Maybe it is disabled, or maybe something else.
Click the Start Orb (or Button in XP) and click Control Panel. There, search for Mouse Settings (or similar). In Vista, you can type what you want in the Search Box.
Posted on Dec 12, 2008
Gateway auto scroll not working
is it a mouse settings prob, or mouse pad?
Feb 19, 2013 | Gateway NE56R10u Laptop Intel Celeron...
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
My touch scroll stopped working for my Gateway NV53A. Can I fix it?
1_9_2013_6_10_09_am.jpeg check it first , by , connect a mouse , go control panel disable it , and use mouse ,turn the notebook , turn on & enable it , may be works , other wise hardware problem.
Jan 09, 2013 | Gateway Computers & Internet
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
The tap feature on my synaptics touchpad has quite working three times, gateway fixed it once, I restored to a prior date one time later to fix the problem, and now I have the problem again. I tried...
Both the tap and scroll features are configurable as to speed.
Try changing their configurations.
The tap has a delay setting, and the scroll setting is for distance.
Jan 01, 2010 | Logitech V220 Mouse
My gateway scroll wont wor9
Scroll on mouse pad may not be a "default" factory setting. Go to Control Panel and access Mouse Settings and look for this feature and activate it.
If this does not work then go to Gateway Website and look for SOFTWARE AND DRIVER DOWNLOADS ., Select your model and Operating System and look for MOUSE. Select Moust Driver Download and RUN and reinstall driver.
If both do not work than your mouse pad has to be replaced due to physical issue
Aug 20, 2009 | Computers & Internet
Try simply using a system restore to before the problem started acting up. Also, you can try going into the mouse properties (Start Menu, Control Panel for Xp) and look for scrollsettings there, which may allow you to turn off certain mouse features (aka. if gestures are enabled it might be conflicting with scrolling).
Hope this helps.
Dec 16, 2008 | Gateway MX6920 Notebook
My scroll on the gateway fx doesn't work
i just went to best buy and thay installed a driver from gateway and wow it works
Oct 30, 2008 | Gateway MT3705 Notebook
4D Scroll Track Finger Mouse Handheld USB Version MODEL FDM-G51 (FN4DUSB) Logo
398 people viewed this question
Top 4D Computers & Internet Experts
Level 1 Expert
ray gallant
Niki Kidman
Niki Kidman
Are you a 4D Computer and Internet Expert? Answer questions, earn points and help others
