Question about Whirlpool Duet GHW9150P Front Load Washer
Duette washer will not drain or spin showing code F 02 what does this mean
  • Whirlpool Master
  • 19,396 Answers
F02 is a problem with the drain pump.
Often this happen when dirt or foreign objects inside the water pump filter,caused damage to the pump impeller, and you need to have the pump replaced.
Posted on Dec 12, 2008
Wont pump out comes up with E3 on display
CLOGGED WATER PUMP HINDERING DRAIN AND SPIN CYCLE
Jun 11, 2015 | Washing Machines
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about...
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 30, 2011 | Washing Machines
Keeps showing code f 02 and wont completely empty water it never finishes spin cycle?
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..
Be sure you are using only 2 tablespoons of HE soap and not more than that. Check your drain filter also and replace them if needed.
Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front
Jan 18, 2011 | Kenmore Elite 45986 Front Load Washer
02f code
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
display.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
or kinked.
My washer show error(f-02
F-02 means that it had a long drain. if the drain exceeds 8 minutes the water valves tuen off. sheck to see if there is a sud error. some of the cuases would be drain pump might be clogged, the drian hose might be kinked, there are foreign objects in the pump.
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duette washer what does code F02 mean
"F02" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If the washer cannot drain properly it will shut down. Cleaning the drain pump is most commonly the remedy for fixing this problem. However, if the drain pump is clear and the drain hoses have been verified clear, it is recommended by the manufacturer that the drain pump be replaced. It does not take much to damage these small pumps. Just because it is running, does not necessarily mean it is actually pumping anything. Irreparable damage can occur to the pump motor and impeller. There are several good web sources available to obtain a replacement pump, if necessary. Some of the better sites I have found are: searspartsdirect.com, repairclinic.com appliancepartspros.com and pcappliancerepair.com. You may want to view all these sites for comparitive pricing.
I hope you find this information helpful and that no parts will be required. But...if you do need parts, at least you know where to get them. Let me know if you require additional assistance.
Dec 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
