Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Only red on Sony Rear Projection 53" TV DRC-MF/MID-X
The TV: Sony Rear Projection 53" TV DRC-MF/MID-X
The problem: Only a red screen at start, then turn off after few second (because the red is getting too bright).
When I unplug the base of the red tube, green and blue are back and TV work fine...without red.
Thanks for you precious help
Donation if I can fix the TV :))
  • 1 more comment
  • wings_it
    wings_it Dec 14, 2008
    You reckon?
    when the green and blue bulbs works without the red, and the red is over powered when all connected??
    Where should be the loss connection? Main board or base of the tube.
    Thanks
    JP
  • wings_it
    wings_it Dec 15, 2008
    I will rate you and hope that I can give some help too.
    I did play around on the mother and the board on the neck of the tube and solde a few point, but did nothing really then I try to shake it (looking for bad contact, nothing again...
    I found between the blue and green tube a plastic box with 6 poties, 3 are for the power of each bulb and the other three for the definition of the picture.
    Playing with those tree first I was able to get a reasonable good picture but with a light red shadow.
    So the problem is not solve but I've got the TV back.
    Before finding this "by pass" solution I saw the stand bye led 6 times blinking.
    Diagnosis: Low B OCP/OVP(Overcurrent/aver Voltage).Possible causes :5+line is overloaded.(A,B boards), +5 line is shorted.
    The sony is a KPFS 53 M31, and I'm not sure that I found the right diagnosis, Can You Confirm if this diagnosis for this TV is right? And Where can I get some more details about the A and B boards? Do you have a ready fix for this problem?
    Those are my last question, promise :)
    Thanks for you help..
    JP
  • wings_it
    wings_it Dec 17, 2008
    Not really satisfied, when I pay for an expert I expecte more details and not the ready answers who's fitting 95% of TV problems.
    But he recommand me someone else so the contact is good.
    I suggest when you don't know, don't answer, especially when we pay for assistance.
    cheers
    Genius:
  • 1,226 Answers
There is a loss connection in your TV...Try to open the circuit and resoldered all the connection. else if you can not dare to fix at your own then contact nearest service center.
warning High voltage!
melnavz
Posted on Dec 12, 2008
  • 1 more comment
  • Emelio Navaja
    Emelio Navaja Dec 15, 2008
    You should rate me thank for try so that your question visible to other expert!
    thanks
  • Emelio Navaja
    There is abnormality pwer supply causing the tv turn off automatically. Verify parts in the circuit board, such that regulator and resistor and capacitor.
  • Emelio Navaja
    Emelio Navaja Dec 17, 2008
    Hello again!
    Since you found out that there is a 6 times blinking, this symptoms due ♦ Abnormal High voltage ♦ Abnormal H.drive ♦ +
    5Vdown, this is horizontal deflection failures, try to verify some ic's maybe it add the fault. continue moving on your findings that helps a lot.
    if this not solved then recommended you to benimur he is more expert than me. http://www.fixya.com/users/benimur
    melnavz
Why my 53 sony drc mf coming sound but on after ten green light blink otometic s of wich
10 blinks won't occur, as per its repair manual. It might be 9.
Audio error If you wish to get some details; check the site linked here. Pull up older posts.
Jul 16, 2016 | Sony KP-53HS30 53" Rear Projection...
A 53 inch sony tv
blink red light and blank screen every two mintue
Mar 18, 2012 | Sony KP-53HS30 53" Rear Projection...
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
HI...WE HAVE A SONY PROJECTION TV, MODEL #KP 53 S 35, NO PICTURE NO SOUND, DARK SCREEN, JUST SMALL FLASHING RED LIGHT ON CONTROL PANEL (STANDBY LIGHT). NO POWER ON SOUND WHEN TURNED ON. TOLD WE NEED...
http://www.moduslinkptstvboards.com/search.php?search_query=A+1316+295+A&x=7&y=13
try this....may have to send board to them for repair.....good success, meder's tv service
Sep 22, 2011 | Sony KP-53S35 53" Rear Projection...
My Sony trinitron drc-mf has now got a sort of negative screen (reddish black) with the actual picture of the DVD player,satellite TV,video ....etc but the menu,channel numbers........etc are all normal
If the Menu Display is normal. DRC module is faulty.This module is installed vertically and has a stainless steel cover, beside Tuner module. If you can do, try to remove the DRC Module,and clean its terminals with paintbrush then put it back properly, if it doesn't work replace the DRC module.
Nov 05, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Dec 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture changes focus/sharpness instantly and then recorrects
Hi
You can try and get more infornation for me.
Go into the the menu by pressing the WEGA GATE button on the remote. In the sub menu of picture adjustment switch the DRC-MF setting to off. It should read normal.
See if this stoppes your focus problem.
If it changes let me know for further directions.
Feb 24, 2008 | Sony KP-57WS500 57" Rear Projection...
53 inch projection tv
try this
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 08, 2007 | Sony KP-53V85 53" Rear Projection...
Sony Wega 34 inch Tru Surround DRC MF
check q8014 and q8013,r8051 and ic8005 on d board
location is seen under the green printed circuit board
Sep 30, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
