Question about Photography
Exposed film in our Fuji STX-2 Camera
We bought a Fuji STX-2 camera and our first two rolls of film came out exposed and we don't understand all the operations of the camera itself and what all it may do.
    Scholar:
  • 95 Answers
What you need is to have a copy of the user guide. Here's a link:
http://www.butkus.org/chinon/fujica/fujica_stx-2/fujica_stx-2.htm
Posted on Dec 12, 2008
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
Two rolls of film developed at CVS - apparently not exposed???
it is not unknown for film developing sites to with hold good photos so take another practice roll and have it developed somewhere else
That will prove either the camera or the developer
Apr 23, 2017 | Pentax K1000 35mm SLR Camera
When I insert a new roll of film into my Canon Rebel S 35mm SLR, it automatically rewinds the film instead of winding it onto the spool. I can't figure out why it's doing this.
this is normal, as these cameras are designed to wind the entire film to the take up spool then as you expose the file will roll back into the cassette. this was a feature that canon devised to protect already exposed film when the back cover is inadvertantly opened.
Aug 17, 2013 | Canon EOS Rebel X 35mm SLR Camera
Owner's Manual for a Fuji Discovery 400 Tele Plus
Here's the owner's manual (link below) .
NOTE -> the DL-400 extracts the entire roll of film from the canister as soon as you close the back. Just the REVERSE of what you would expect. Then every time you take a picture, the camera rewinds the exposed (single shot) picture back into the cannister. When loading the film, YOU MUST PULL OUT ENOUGH FILM FROM THE CANNISTER TO GO ACROSS THE ENTIRE BACK OF THE CAMERA. There are 7 little notches on the botton of the cover. You won't see them until you open the back. The film MUST be extended far enough to reach the notches.
link
http://www.butkus.org/chinon/fujica/fuji_dl-400/fuji_dl-400.htm
May 09, 2010 | Photography
I may have loaded film roll that has already been taken?
Usually when you finish exposing a roll of film, you rewind it until you are sure it is all wound into the cassette. There is a change in the sound as the end of the roll leaves the camera. An exposed roll would have no film sticking out of the cassette. A new unexposed roll will have a bit of film sticking out of the cassette to pull across the ack to the take up roll.
May 26, 2009 | Canon Elph LT APS Point and Shoot Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Problem in camera or film roll??
Hey msenile,
It is possible that each frame would have image data imprinted without and image being exposed. This could be caused by the shutter not opening while the camera still exposing the film internally with the image data recorded. It is unlikely that this bad film since the emulsion covers the entire surface of the film and if it were bad the image data would not be recorded either. Another cause of this but very unlikely is every frame was somehow extremely underexposed. This could happen if the camera is set to manual and the light level is low and the shutter speed is set to a fast speed and the aperture is set to a very small aperture. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 18, 2008 | Nikon F80 35mm SLR Camera
Flashing HI
there is a flexible ribbon cable carrying signals from camera body to the lense assembly. Due to regular use it gets worn out, thus it gets broken and is not able to perform the task for which the camera has given the signal. in your camera also the same flex cable is broken. Get it changed at some good repairer
Oct 26, 2006 | Pentax IQZoom 928 35mm Point and Shoot...
Photography Logo
304 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
