Question about Maxtor 7Y250M0 250GB Serial ATA 7200rpm 8MB Hard Drive, OEM (DSMXSATA250G8M)
How do I make my MAXTOR Hard Drive 7Y250M0 a slave?
My drive has no diagram where to place the "pin sleeve" to make it a slave
  • nyteflyer Dec 12, 2008
    TY soo much for taking the time to answer (what I assume) is a novice problem. However, you were very helpful and I sincerely appreciate it:)
  • 4 Answers
A slave drive is defined by removing the jumper (pin sleeve) completely from the drive. Then go into your BIOS and if it doesn't auto-detect as slave, manually change the settings and you'll be good. You shouldn't have to go into your BIOS.
If you can see it as slave in BIOS, but not in Windows that means the drive is not formatted properly and to do so, Right click on My Computer in Windows and goto Manage. It should load the Computer Management window. From there goto Disk Management under Storage in the left side browser. You should see the Hard Drive there, right click on that and format it.
That should do it.
Posted on Dec 12, 2008
How place "cavalier" for maxtor
there's a diagram on top of the drive.
Feb 25, 2011 | Maxtor Hard Drive
I have an old maxtor 2 drive that i'm trying to slave
Hi!
Just follow the jumper settings in the picture diagram below:
I hope it helps..
Thank you for reaching Fixya.
Apr 11, 2010 | Maxtor Hard Drive
I dont know how to set jumpers to work as a slave
Just look for the little plastic squares that slide onto two pins. They will be where you you plug the cable and power into the hard drive.
There should be a diagram on the label. If not, you can look at the bottom of the hard drive - right by the pins, and you should see SL, CS..... in small text on the green board. This is for SLave, Cable Select........
Go to the maxtor website for more details.
Feb 27, 2010 | Maxtor Hard Drive
What is the jumper setting for 'Slave' on Maxtor
Look at the picture, I cannot memorize all hardisk jumper but almost all drives have label in it. where you put the jumper for the Cable Select, Master, Slave.
See picture below. Opposite pins has label on it to where you put the jumper.
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Installing old maxtor HD on newr pc, have to change it to a slave
J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
Jul 26, 2009 | Maxtor Hard Drive
HD not being detected
Sounds to me its a bad hard drive. Set it as slave and install it into another PC with enough empty hard drive space to copy all needed files. Try to observe also your hard drive if there's any clunking sounds and if it does any, eventually that drive of yours is just waiting the right time to give in.
Back up your files as soon as possible.
Jul 06, 2008 | Maxtor 7Y250M0 250GB Serial ATA 7200rpm...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Jumper settings
how many pins in that hard drve?..let me analyze to you this, if the hard is in front of you, you'll see the connection of the ide cable and power cable, then the jumper setting pins is in your left,am i right?..so the pins is figure like this, : : : ., is that right?..the first pin(from top to bottom)is the master, and second one, is the slave and the last is cable select..
Feb 26, 2008 | Maxtor DiamondMax Plus 6800 (92049U6) 20.4...
Jumper Settings
another place to look is on the circuit board where the jumpers are connected you'll see : MS, CS, CAB, a space and TXD.
Cheers
Oct 13, 2007 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
Maxtor 7Y250M0 250GB Serial ATA 7200rpm 8MB Hard Drive, OEM (DSMXSATA250G8M) Logo
511 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
