Question about Nikon F3 35mm Film Camera
How do I put the neg and Pos 1.5 batteries in Nikon F3
I am trying to replace batteries in Nikon F3 camera. I found the 1.5 batteries, but no idea how to put them in as it says + and - . I lost my manual and would appreciate any help. Thanks. I
  • 95 Answers
If you undo the battery cap and pull it out , then hold it under a bright light you will see a picture of the batteries with their orientation depicted on the side of the plastic sleeves that will hold the batteries. Look for the shape of the batteries and make sure you load them in that same orientation.
Once loaded, remember that you need to pull the advance level back about 20 degrees to activate the power and the light meter.
Posted on Dec 12, 2008
How do I hook up this unit Two wires or four
Almost all car batteries have 2 pos and 2 neg. More precisely, 1 pos post and 1 side connector, 1 neg post and 1 neg side connector. You only usually use use one set or the other depending on what connectors are on the end of your cables. You can connect something else to the side posts if you need to, but generally only pair is used.
Feb 28, 2015 | Cars & Trucks
I just bought a Digipower model TC-U450 and am trying to charge a Nikon EN-EL20. My battery has 4 contact points but there are only 2 prongs on the charger. How do I charge my battery with this charger?
The battery has 4 contact points, but there are only 2 that are charge points. The + (pos) and - (neg) are the ones you need to adjust the charger contact points to make connection with.
Dec 25, 2014 | Cameras
I replaced the battery terminal cable ends. Now the car will not start, There is a clicking noise from the starter.
Bad connection on cable ends or where they connect to battery. Quick check is if you have a good set of jumper cables, use the jumper cable as a replacement for what maybe the defective one. Hook negative cable good to battery neg. post and then put other side on neg cable to engine ground on block. See if it cranks, if it does than the trouble is on the neg. cable. If not then put positive cable on pos. post of battery. Then put other side of pos. cable on the starter post, try to start. If it cranks then the trouble is on the pos side of cable. Hope this helps.
Nov 16, 2013 | 1996 Geo Prizm
Baja 90 is difficult to start
Check for spark using a new spark plug and clean the carburetor / air filter.
Aug 01, 2009 | 2005 Qianjiang QJ150
Light meter not working
Make sure the battery lid is securely screwed on, The meter wont work before the '1' frame. i just found out last week about this. make several clicks till the '1' mark appears, now check the meter if its working. [A] - aperture prio
Jun 09, 2009 | Nikon F3 35mm Film Camera
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
Mar 01, 2009 | Minn Kota Boating
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
I am trying to replace the batteries in a Nikon F3. I found the batteries, but it says - and + and I have no idea how to put the batteries and too vague.
Look on the side of the black holder that's part of the battery cover to identify which side is up. On the battery the + side is usually marked - if not it's the solid case side. The - side appears to be an insert in the battery.
Dec 12, 2008 | Cameras
Canon AE-1 with Program
Have you change with a new battery?
Or check the battery with a DVM(digital volt meter).
Or get some batteries and connect in series to equal to that voltage and use two wire leads. One lead to -negative side of the battery, other lead to +positive. Now, -neg to neg of camera and +pos to pos of camera.
You now have power to the camera to test. This will save money rather than buying the camera's battery for testing. AA, C or D will work, just look on the camera's battery to see the right voltage.
Examples: with two batteries (1.5VDC + 1.5VDC = 3..0VDC). So -(negative) of one battery to + (positive) of the second battery with solder.
-(-neg, battery, pos+) solder to -(neg, 2nd battery, pos+)+
left side , use black wire on -(Neg) and solder
right side, use red wire on +(Pos) and solder.
Now you have two leads, use those to connect to camera.
Do you get data from viewfinder?
Dec 10, 2007 | Canon EOS-AE-1 35mm SLR Camera
New Camera Does Not Charge
A red flashing light does NOT mean it charging. THat means you have a defective battery. Call tech support and tell them that you have a defective battery and they may be able to get a replacement for you.
Jun 08, 2007 | Casio Exilim EX-S600 Digital Camera
Nikon F3 35mm Film Camera Logo
199 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
