Question about Creative Labs Zen Digital Media Player
Why does my zen, starts to display Rebuilding, and its not movin.
At all? when i connected the player to the computer, for charging, its suddenly displayed rebuilding... but it doesnt move at all? and then i press the reset button, and opened it. the rebuilding display starts again,and it doesnt move?? i used the recovery mode and used the clean up... then it diplayed the scan disk...
ctf1800
  • 4402 Answers
SOURCE: Recovery Mode
  • Detach your player from the PC if it is connected, and turn off the player.
  • If the player stops responding, you can reset the player. To reset the player, gently insert a thin object into the Reset hole located below the power switch.
  • Press and hold the Play button while powering on your player.
  • When the player displays the Creative logo, release the Play button.
  • It will display the following options:
    Clean Up Scans the player and removes invalid links from its music library.
    Does not affect music files themselves.
    Format (All) Caution! Erases all content!
    Save a copy of your player's content before formatting.
    Reload OS/ Firmware Caution! Erases your player's firmware.
    DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
    Reboot Reboots the device.
    Posted on Dec 06, 2007
    SOURCE: freezes at "rebuilding library"
    I just found this on another website and it seems to be working so give it a shot
    Listen!!!!! Anyone having problems try this before you blame the product. Turn off player........remove battery.......hold on button ON and put battery back in while still holding the power button on. When power comes on release the power button. You should now see a clean format and re-boot screen. Use the clean function two times. After the second time go down to reboot and should be fine. Worked for me. The Zen Micro Photo is a sweet mp3 player. Dont blame the product for something YOU most likely did. This will fix 99% of your players problems
    Posted on Dec 08, 2007
    • 7 Answers
    SOURCE: mp3 stuck in rebuilding library mode
    try pushing the restart butten(diden't work on my zen,but worth a try). If that fails try plugging it in to your computer(that worked on my zen) ......
    Posted on May 21, 2008
    ThaMp3Doctor
    • 8596 Answers
    SOURCE: Rebuilding
    You need to use the Recovery Tool from Creative's website at support.creative.com
    Creative Zen
    Try another PC or another USB port
    Make sure the hold/lock is not engaged
    Reset
    Check for firmware update on Creative's website
    Get Recovery Tool from Creative
    Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
    If all else fails, check with this guy:
    http://www.mycreativefansite.com/2007/05/myzenchecker-tools-guide-to-problem.html
    Creative Zen – Formatting
    Step by step instructions for formatting a player
    1. Detach the player from the PC if it is connected, and turn off the player.
    2. Press and hold the Play button while powering on the player.
    3. When the player displays the Creative logo, release the Play button
    4. Select Format (All) and select Yes to format the player.
    5. After the player has finished formatting, select Reboot.
    6. Re-transfer the tracks to the player.
    -Tha Mp3 Doctor
    Posted on Sep 27, 2008
    cambunctious
    • 61 Answers
    SOURCE: Creative Zen Rebuilding Problem (Freezing)
    Hold the reset button with a paper clip AND the play button at the same time while flipping the power switch. The ZEN should go into recovery mode. You probably want to do format all but you can try the different options. You also may need to download/update the firmware here.
    Posted on Feb 13, 2009
    My m3 player says rebuilding and it won't stop saying that I don't know what to do. (it's said rebuilding for a couple of days)
    Hi
    Try and reset the player by inserting a pointed object inside the small hole, press and hold for 5-10 seconds to let the player reset. If this doesn't work then connect the player with the computer and let it charge. Please check this link for details---
    Creative Zen player reset
    Please post for any further assistance. Hope this helps...
    Daniel
    Sep 03, 2010 | Creative Labs Zen Micro MP3 Player
    Zen v plus 8g
    If you already try both reset, then try doing a firmware update.
    On computer try unplugging computer power cable, and if it is a laptop also remove battery, this sort out problems related with electrostatic charges on computer USB ports.
    Sep 14, 2008 | Creative Labs ZEN V Plus MP3 Player
    Zen player mosaic crashes re-building library (uses flash memory)
    I've been having the exact same problem. No matter how often I reset it it still becomes stuck on the rebuilding screen. I was thinking I may just copy all of my music onto my computer and then do a complete reset on my Zen and copy it back but I don't want to go to all that trouble if there is an easier way to fix it.
    Jan 25, 2010 | Creative Labs Creative Technology Zen MP3...
    Creative Zen M:vision - can't turn on/off, permanent blue light
    Well, i didn't charge mine over night, was listening to it in the evening while doing some chores and all of a sudden it stopped playing, Blank screen and permanent Blue light. I tried to turn if off but it didn't respond so i left it. In the morning, it went off itself (guess the battery was low). So i connected to the computer and inserted the ZEN CD. As i was exploring the CD looking for a solution, then all of a sudden the screen came up with a note "Rebuilding..." after 5 secs it came on. With all my files intact! I hope this wud be helpful, You could give it a shot, after all there's nothing to loose!
    Jan 15, 2010 | Creative Labs Zen Digital Media Player
    Zen V Plus locked up, will not shut off
    After 3 1/2 hours, the battery went dead. I waited a couple of minutes, then plugged it into my computer to see if the battery would charge. It started charging. A few hours later I went back to check on it, and it showed a full battery. I disconnected it from my computer, and turned it on. It came on, but the screen just said "Low Battery". I then plugged it back into my computer, and the screen said "Rebuilding Library". I left it for about a 1/2 hour, and it was done. I unplugged it from my computer, turned it on, and it works now!! Hope this helps out everyone else who has the same problem.
    Feb 12, 2009 | Creative Labs ZEN V Plus MP3 Player
    Feb 07, 2009 | Creative Labs Zen Digital Media Player
    Mp3 stuck in rebuilding library mode
    hello guys sorry to hear your problems i have same problems too. Ok first plug ur zen player (mines V PLUS.. heheh) to ur pc then hold play button then keep pressing the reset botton until it turns on RECOVERY MODE then select YES to all (clean up, format, reload firmware) then download the RECOVRY TOOLS at creative site install it then plug ur zen player and run the recovery tools (cross ur finger) hopes it works mine a big smile hehehe email me at oracle101rage@gmail.com if it works..Gud Luck guys
    May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
    Zen stone mp3 player not switching on
    Mine was also completely dead, with the reset doing nothing! I held the vol+ and the Play button at the same time and it was good to go. Holding just the play button or the vol+ button didnt acheive anything. But as I held both together, It came back to life instantly and I havent had any problems with it (for a week so far).
    May 08, 2008 | Creative Labs ZEN V Plus MP3 Player
    Not rebuilding Library all the way
    1. Press and hold the Play button while powering on your player.
    2. When the player displays the Creative logo, release the Play button.
    Clean Up
    Oct 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
    Creative Labs Zen Digital Media Player Logo
    37 people viewed this question
    Top Creative Labs Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Mohamed Ismail
    Mohamed Ismail
    Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
