Question about Brother SE-270D Computerized Sewing Machine
Bobbin thread comes out on top
When I embroider with say RED thread and black bobbin thread, the embroidery is BLACK, instead of red.
Any ideas?
  • 3 Answers
You need to read the section of your manual that talks about thread tension. That occurs when your thread tension is off.
Posted on Dec 16, 2008
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Needle up down moves the embroider
It's okay - it's supposed to do that! The Needle Down button has a different function when you are in Embroidery mode i.e. you have the emb. unit attached.
It moves the emb. arm forward for two reasons: so you can cut top-side jump stitches more easily between colour changes (you touch the button again and the emb. arm returns to under the needle so you can finish the design); and secondly so you can "park" the embroidery unit when you are finished. You can then turn the machine off, remove the emb. unit and replace it in the carry case. If you DON'T do this, the emb. arm is not in the right position to fit into the moulded carry case properly.
The Broken Thread message usually means that it has started the colour, but the thread has been pulled down underneath instead of making nice locked stitches. Hold onto the thread end until the machine has stopped and beeped for you to cut the thread. This usually solves that problem. Sometimes the thread gets pulled out of your hand so just back up the stitches a few and start over, holding the thread more tightly. Don't tug on the thread - just keep a firm grip.
Designer 1s often cut the bobbin thread too short so that it can't make those nice locked stitches when it starts. You need to take off the hoop, open up the bobbin cover and use your stylus, the tip of a pair of scissors, tweezers (whatever is to hand) to pull the bobbin thread out a little. Instead of cutting it on the bobbin thread cutter, just let it hang outside by 1/8" or so. That way you can be sure there is enough bobbin thread available for the stitch to lock. Don't use the scissors button on the machine after every colour change. Sure, it makes for a tidier back of the embroidery with less work for you afterwards, but if it means you are taking the hoop and bobbin cover off after every colour change then it is not worth it in time-saving.
If your machine is doing this - cutting the bobbin thread too short - mention it to your tech. when you machine goes in for its next service. He may be able to tweak the bobbin cutter so it does not cut so close.
Jan 05, 2010 | Husqvarna Designer I
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
Jun 07, 2017 | Baby Lock Ellure
Embroidery Problem with my disney
Check your bobbin case. Thread the bobbin through your bobbin case while holding it in your left hand. Pull the thread with your right hand and feel if there is any resistance. If not, you need to adjust the tension on the bobbincase. Also check if a piece of thread or fluff did not get stuck between the tension blades on the bobbin case. If you are not sure how to adjust the tension on the bobbin case, ask your dealer to do it.
Dec 18, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
