Question about Jenn-Air JMC7000 Microwave Oven
Need New Microwave
I need to replace a Jaenn-Air Wall-Mount Microwave Oven Model M167 Series made in 1993. The wall mount (outer case) is fine, but the interior has begun to flake off. How do I measure for a replacement? Do I measure just the unit or the whole wall mount? And where do I find the capacity? It's not on the unit or in the Use and Care Manual that I can find. Make it easy on me and just tell me what model to replace it with.
  • Jenn-Air Master
  • 9,086 Answers
Is the interior flaking the only problem with it?
It can be sanded smooth and clean and dried thoroughly, then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, if you want to replace it, I would suggest contacting Jenn-Air Customer Care here and telling them your model number.
They can probably give you the model number of a new "drop-in" replacement.
Posted on Dec 13, 2008
Electrolux wall mount micro wave oven combo doesn't work
Good Morning Friend,
I understand that your Electrolux wall mount microwave oven combo is not working. I see that the oven is working, but the microwave is not. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please provide me with the model number of your air conditioner. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux EI30MH55GS Microwave Oven
I'm getting conflicting directions on how to replace a fuse in my JVM1440...Is there more than one way to access the fuse. One said to take the MW off the wall, remove the case, then have access to...
Hello there and thank you for choosing fixya
Actually the unit does in deed have to be removed from the wall because the outer shell does need to come off there is a series of screws on the edge of the back that need to come off and there are some on the sides then the outer cover will slide to the back about 1 to 2 inches then lift off and the fuse is on the control board towards the front right as you are looking at it from the front of the microwave ok
Hope this helps best regards mike
May 11, 2011 | GE JVM1440 Microwave Oven
Wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Jan 10, 2010 | GE Profile Over-the-Range Microwave
Was microwaving a hotdog on a paper plate covered by another paper plate and the microwave just kind of went poof and now nothing lites up (display) and it wont work. I checked the breaker it is on and...
Yes there is.
Unplug the MW.
Uninstall from wall mount (if installed that way.).
Remove outer cover by removing the screws at back and (possibly) bottom sides.
Locate fuse. Replace only with an equivalent type and amperage.
You can test the MW without reinstalling or putting the outer covering back on.
Dec 21, 2009 | Kenmore 63672 Convection/Microwave Oven
I need a wall mount bracket for a ge spacemaker micro, but I have no model #
To get the wall mount you need to call GE here at this #.
1-866-775-4557
GTood Luck and Please Rate
Sep 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchenaid microwave bulb
You can download the owner's manual and installation instructions here.
You can also download the parts manual here. It has handy exploded views. The bulb is shown on page 5 and is ref # 75.
You will need these instructions, because to replace the bulb, you will need to pull the microwave down from the wall mount and remove its cover.
Always unplug a microwave before removing or installing any bulbs.
And it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you don't find a replacement locally, check here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 05, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
How do I install my Kenmore Microwave Oven 721.63664300 to the wall
You can usually find exploded views and order parts & manuals by entering your model number here at the Sears parts site.
Aug 13, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
REMOVE WALL MOUNT MICROWAVE
TO: capt_bob1954:
You can find an exploded view of the outer case & installation parts for the 564.8775380 model here. Maybe that will help.
If not, on that same page, it shows where you can order a copy of the installation instruction manual for $4.99. It's probably worth it to save a lot of aggravation.
We're happy to help and we appreciate your thoughtful rating of our answer.
TO: Guest
You can find an exploded view of the outer case & installation parts for the 665.68601891 model here. Maybe that will help.
If not, on that same page, it shows where you can order a copy of the installation instruction manual for $9.99. It's probably worth it to save a lot of aggravation.
Feb 19, 2008 | Microwave Ovens
Removing Microwave
I just got my Whirlpool MH7100 off the wall. It was a bit of a hassle. I could not find a proper manual online at Whirlpool, but I guess since my unit was manufactured in 1993, who can blame them? Was the Internet even around in 1993?
There were 2 obvious bolts to remove above the microwave, these were found by opening the cabinet above. The next step was the hard one. Even after these were removed, the microwave would not lean forward so that it could be removed from the rear brackets. To get it to lean forward, I had to partially remove and partially break (i think) the vent for the exhaust fan. This revealed what looked like a very large screw with a regular head, one on each side. Once I unscrewed both of these, I was able to lean it forward and get it off the rear brackets.
Nov 25, 2007 | Microwave Ovens
GE Spacemaker Microwave
On these models, the oven must be pulled from the wall mount, then the outer cover must be removed. This is apparently to limit the manufacturer's liability. Removing the microwave from the wall is really a two-person job, since it is heavy and awkward. You don't want it to fall or slip, and the edges can be sharp. It helps a lot if you saved the original installation instructions. Once the oven is out of the wall, you can then access the lamp socket. These bulbs are special halogen types that must not be touched by bare hands, since skin oils will shorten their life. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Sep 23, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
314 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
