Question about Zenith SY2551S TV
I have sansui TV model TVM2515G/B, i cant find any port expect 1
Hi, i have sansui TV model TVM2515G/B, i planned to connect my laptop to my sansui TV, but my tv doesnt have ports for that. I can see only one port (ANT). Please suggest me 2 things:
1) what i need to buy to fix ports to my TV ?
2) what cord i need to buy to connect my TV to Dell inspiron 600m laptop ?
Many Thanks in advance...
Please give me advices..
3 Suggested Answers
shaggy067
  • 56 Answers
SOURCE: Blue Box in the Corner won't turn off!
That problem might be on the remote of display settings on video display. There is one button that will turn that off. Try Display Settings
Posted on Nov 14, 2006
  • 643 Answers
SOURCE: I do not find a vedio/audio(red, yellow,
If you have a Zenith, C27A24T
Then on the rear left side, should be the rf cable input, and also the red, yellow, and white jack inputs..
If those arent there for some reason..
As long as you have the screw on rf connection on the back of the tv...
then you can purchase a rf converter..
here is a link to an example
http://www.radioshack.com/product/index.jsp?productId=2103095
Posted on Oct 31, 2009
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
I cant connect my tv to computer
Hello
All modern TV's can be used as computer monitors - you just need the correct cables and select the correct input on the TV.
What cable are you using to connect your PC to your TV? VGA or HDMI? Your listed TV has both ports but your computer may not have a HDMI port. Either way, connect the correct cable from your PC to your TV and note how the port is labeled.
Turn the TV on and then find the "Input Select" button on the remote and press it until the above port appears on the screen.
If you use the VGA port, you will need to hook up the audio from the PC to the "PC/DVI Audio In" port so the sound will play on the TV speakers.
You can find the manual for your TV here:
http://www.sansuiproducts.com/products.html
Hope this helps!
Nov 09, 2013 | Sansui Televison & Video
Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Jul 18, 2013 | Televison & Video
How to connect my sansui to my laptop sony vgn-txihp
the VAIO model vgntx1hp must have a VGA port on it, you can connect the TV to the 15pin VGA port. press the Fn+F7 keys on the VAIO to toggle the displays between the external TV and the VAIO screen.
Dec 12, 2010 | Computers & Internet
How to connect a dvd player to a 19" sansui tv? this tv have all input ports. What I am I doing wrong? blrfrd@yahoo.com
Hi Is it not just a case of connecting a scart lead to the TV scart on the DVD, then into the Full Scart socket on the TV or have you done that and are having probs with it?
Dec 06, 2009 | Sansui HDLCD1908 19 in. LCD TV
Does my Sansui, model TVM2515G/B, have a digital tuner?
I'm sorry, but the TVM2515G/B is not digital. If you use an antenna you will need a converter box.
Jan 08, 2009 | Sansui HDLCD-2600 26 in. LCD Television
Adding dvd player to sansui model TVM2515G/B
no way that you wil get a satisfactory output. so better change the circuit board alone in your TV. it wont cost much. but u can get many facilities on changing it. you can get this done at your local electrician shop.
Dec 23, 2007 | Televison & Video
Televison & Video Logo
99 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
