Question about liftmaster Electrical Supplies
When I try to click the switch to open garage door . I only hear.
I only hear a click and Motor does not start.
  • 22 Answers
Do you have electronic eye at the base of the door track. sometimes they may have been twisted and will prevent the door from opening. this is a saftey device. make sure they are both pointing at each other. Also check if somethong is blocking the view from the elec eye. this is easier than it sounds. A question for you, does this happen all the time. some times if the sunlite is directly on the elect eye it will not work. stand outside and block the sun from hiting it and it may work. You may want to check if the wires are connected to the elec eyes.
tom
Posted on Dec 13, 2008
Overhead Garage Door Opener
Sounds like the motor has failed. Clicks is the solenoid, buzzing is the windings on the motor trying to move. You can check if the motor turns by hand, and if it does, you need a repair person.
Jun 16, 2016 | Building Materials
Garage door opener just clicks when we try to open it with the switch
Remove the cover from the motor unit and check the drive gear. It will be obvious if it is bad. It is a white nylon gear just in front of the motor.
Sep 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
I had a lightening strike at my home. Since then, the garage door does not function with wall switch or remotes. when i press the switch, light comes ON on the door opener and i hear a click but nothing...
Well, I don't think that disconnecting the garage door from the garage door opener would affect function.
The lightning strike could have destroyed the circuitry inside the garage door opener, seeing that it won't operate with the wall switch or remotes.
It's likely that a board was fried by the lightning which would render the garage door inoperable.
Aug 08, 2010 | liftmaster Chamberlain Garage Door Opener...
Liftmaster 1/3hp garage door opener
When i try opening the garage door from the wall button the door only opens 3 inches or so, then stop but makes several loud clicking noises. I've played around with the travel limits as well as the open force switch but the same thing keeps happening. Any suggestions?
Jun 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: when i push the wall unit i hear a click from the ...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. It may be going bad.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Garage door opener (139.53800SRT)was working and then just quit working. None of the remotes or wall switch work. When I press a switch I hear a few click in the opener and then nothing. ...
The code for 5 flashes is " Motor overheated or possible RPM sensor failure. Unplug to reset." Also if the door is stuck in the open position it could be the trolley is jammed against the bolt just in front of the motor unit.
Feb 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster 1/2 hp garage door opener and when I push the remote and hear 2 clicks from the motor, and the led light flashes 5 times. I have unplugged it and the system resest, but then does the...
UNPLUG THE UNIT TO RESET
TRY TO OPERATE MOTOR. IF IT STILL FLASHES 5 TIMES AND THE MOTOR MOVES 5-6 INCHES, CHECK THE RPM SENSOR - A LITTLE CUP ON THE MOTOR SHAFT WITH A SENSOR.
IF MOTOR DOESN'T OPERATE AT ALL MOTOR MAY BE OVERHEATED - WAIT 30 MIN. & TRY AGAIN. IF THE MOTOR STILL DOESN'T MOVE IT IS MOST LIKEKY A BAD CIRCUIT BOARD.
Jan 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Craftman Garage Door Opener Quit Working.
It could be a bad logic board especially if you have had any electrical storms in the area. I would remove and check the logic board for burnt or missing traces on the printed circuit board.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
Pop open the cover and check for loose wiring. Also check to see if the capacitor is still good that powers the motor.
Apr 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Electrical Supplies Logo
117 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
