Question about Sharp Notevision PG-M10X Multimedia Projector
Flickering image The lamp is correct with stable shining light not used many hours. Still picture is flickering with grey colours. Reset to industry settings does not help. Is it just to smach the thing hard or any other suggestions? Thank you, Problem Solver Yeah
Have you check your cable? Are you using the component(RGB) to vga cable? Your vga to vga cable may be defective.
Posted on Feb 01, 2009
Mitsubishi tv flickering
the problem you are having is the colour wheel. it spins to correct the colour on the screen when it fails you get wrong colours and flicker... the motor on it fails after time. and will need replacing.
Mar 05, 2014 | Televison & Video
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
Screen
You have a hardware problem.
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 10, 2009 | Acer Aspire 5610-4648 Notebook
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Dlp picture problems
dear,
if you have checked it by changing the lamp then there you will see a thin peice of coloured plastic (colour wheel). Vacuum that plastic and all around it but dear plz dont touch that one.
regards,
Aug 16, 2008 | Toshiba 46HM95 46" HDTV
Lamp
Hi Striker 53
Yes , a flickering image and dimming is a very clear indication that the lamp is going.
To make 100% sure and to give you some peace of mind - take out the lamp and you will either see vein like looking marks on the lamp or discolouration or even that there is a bubble at the end of the lamp's shaft.
Do keep in mind that a lamp normally gets a rating of say 2000-3000 hours , but that is only a estimate from the manufacturers factory. I've had lamps that had less than 300 hours on them , that needed replacement.
Once you replaced the lamp , remember to reset the lamp timer.
Apr 20, 2008 | Toshiba TDP-MT200 Multimedia Projector
Flickering and freezing of picture for a split second
The most likely problem for image problems and flickering is the lamp (23311083A). I found it at PartStore.com for about $180. Hope this helps.
Nov 11, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
The image projected from my CTX EzPro 680 Projector flickers on screen
From my experiences working with projectors, more than likely you will need to replace the lamp
Oct 04, 2007 | CTX Optoma EzPro 680 Multimedia Projector
Sharp Notevision PG-M10X Multimedia Projector Logo
260 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
