Question about Gateway MT6730 Notebook PC
Internal microphone in gateway turned off, now will not turn on.
The internal mic in my gateway laptop with windows vista is turned off. In my control panel it says that it is enabled and working. How can I turn it back on?
  • Anonymous Jan 11, 2009
    i have the same prob. and idk how i'm supposes to fix it or how i'm can find the webcam on my computer list and its important that i can find this stuff and that i can work my mic cause i have a daily live webcam show that i host and i have not been able to be on since i got my gateway
  • baggers296 Jan 27, 2009
    I've been fighting the same problem on a P-7811FX
    Tech chat says to reload the operating system. That will of course delete everything on your hard drive. I've been uninstalling and reinstalling the Conexant driver. Sometimes a Microsoft driver will take it's place for no reason that I can tell. The internal mic will work for awhile after I fight with the drivers and then it will stop the 3rd time I reboot. Tech support is no help and we are on our own.
  • 4 Answers
You may need to raise the level by going back into Control Panel -> Sound. From there, click the Recording tab -> right-click Microphone and select Properties. Finally, click the Levels tab and raise the level.
I had to do this on mine, too.
Hope this helps.
Posted on Dec 12, 2008
In windows 7 I had to go to control panel - hardware and sound - sound - manage audio devices - recording - select device - properties - then enable microphone boost to 40x
Posted on Apr 21, 2010
Does the emachines e525 have an internal microphone
high definition audio device not plugged in
Nov 12, 2011 | Computers & Internet
Hi, Internal microphone on my acer aspire 8920g which originally has vista is not working now on windows 7. To be honest I didn't pay attention while I had vista and can't now remember if it worked at...
I suggest you go into control panel and device manager and see if your internal mic is listed there. If it is right click on it and see if it is selected as your default mic. I believe it may be un-selected. If that doesn't work I would just use the external mic with Skype as the internal mics with most laptops aren't that good anyway.
Mar 06, 2011 | Acer Aspire One PC Notebook
I have a new toshiba laptop and I want to know how to turn on the internal microphone
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 18, 2011 | Toshiba (P000257700) Microphone
My Mic is on all the time it is also coming through the speakers so when i turn external speakers on there is an huge feedback
See Adjust volume below
To use any microphone with your computer you will need to enable it in control panel. Instructions are for Windows XP but are similar for Vista and Win7
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and the volume slider is at the top of the scale.
Ensure the MUTE ALL box isn't checked before closing window.
Click VOLUME button in SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. The same applies to 'Internal MIC' if you are using a laptop with built in microphone - this must be enabled/ disabled separately to the external MIC.
To adjust audio volume.
You can also put a check mark in the box to show the volume control icon on the Task Bar so you can go straight to it to in future
Feb 10, 2011 | Toshiba (P000257700) Microphone
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
Internal microphone problem
check the mic settings, sometimes it is not sensitive, boost the mic settings and try it again. it should work.
go to volume settings and check and advance settings for the mic and from there you will see the boost settings and other recording tools as well
May 21, 2010 | ASUS Eee PC 900 PC Notebook
I install the windwos 7 on my gateway laptop but
if you right clik the speaker in the bottom right task bar tere should be recording tab make sure your mic is set to default
Apr 05, 2010 | Gateway MT6730 Notebook PC
Microphone
Hey Marie,
Try doing a test recording in the Windows media recorder. Chances are you will get a wave signal if it has an internal mic.. Usually laptops have built in mics but descktops don't.
Hope that helps,
Ian
Apr 10, 2008 | Audio Players & Recorders
How do I turn my internal microphone on, please help
1)Double click on the speaker icon in the system tray to bring up windows volume control. 2)Go to options, then properties. 3)Select adjust volume for recording. 4)Make sure microphone is ticked. 5)Click ok. 6)Select the microphone in the windows volume control. Your microphone is now on. Just set the appropriate volume for the mic.
Aug 02, 2007 | HP Pavilion dv1000 Notebook
Gateway MT6730 Notebook PC Logo
5,774 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
