I have qsc amplphier and a behringer eurorack and trying to hook up 532e Graphic EQ to it, how please? Not sure of what I can get away with far as cords go and where do i connect it?
  • 905 Answers
You have to use a tape monitor record in and out connections ( RCA )
it will require two sets of rca jacks ( left and right) (eq in to record out on reciever tape monitor / eq out to reciever in record on tape monitor )
Posted on Dec 12, 2008
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
How to hook up 18"
Hello!
SO I am going to give you more of a signal layout from the turntables (or whatever you use to DJ) to the speakers.
Turn tables-> Mixer-> Eq-> Amp-> Sub and other speakers.
The part that I am not understanding is why do you need the QSC amp if you have a powered sub? The powered part of that means that there is a built in amp, which eliminates the need for the QSC amp unless you are sending that sound to main (non sub) speakers.
Hope that helps!
May 03, 2011 | Audio Players & Recorders
HI, I just need the value/taper of the 30mm slide potentiometer used in the equalizer of the Behringer K1800XF.
The sliders in almost all of the EQ's in Behringer are linear taper (B). The values are usually 50K. Fo replacement make sure you get matching mounting spacing. Almost all Behringer pots are made by ALPS.
Note that the rotary volume controls are G (graphic) taper, often 50K and are hard to get. trying to get these from the Behringer parts distributor was futile... gave up after 4 months wait.
Apr 28, 2011 | Behringer Ultratone K1800fx 180w Keyboard...
Hook EQ to my mixer
I assume you want to put the EQ on the mains output of the mixer -- is that correct?
Just run the left/right out from the mixer to the left/right in on the EQ, then run the left/right out on the EQ to your amp.
May 27, 2009 | Behringer ULTRAGRAPH PRO FBQ3102 Turntable
Hook up an eq to a mixer
yes any EQ can be put inline of any sound producing insterment....but why?
Apr 24, 2009 | Behringer Audio Players & Recorders
How do I up Receiver/EQ/Amp?
In the order you state them.
Receiver, EQ, Amplifier,
These graphic eq's and the amplifiers are pin 2 hot on the XLR by default (which is the norm) unlike some other makes. Handy to know when making up cables from receivers like this.
Mar 23, 2009 | Audio Players & Recorders
73 people viewed this question
 Grubhead
Grubhead
