Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
No ice in Kitchenaid model KUIS18NNJB8
Water circulating pump works in the cleaning mode but not in the ice making mode.
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
mikedurland
  • 481 Answers
SOURCE: kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
geemarie
  • 876 Answers
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
The pump does not circulate water after priming
Make sure you are in pool mode, and if you are not circulating, then you have a clogged impellar. Make sure the basket is empty and good, clean the impellar, backwash, or clean filter, put valves into pool mode, prime pump, and you will be ok.
Jan 05, 2017 | Pool & Spa
Ice maker kitchen aid kuic18nnts won't pump water over chill plate. Replaced circulating pump still no water.
Does the circulating pump- pump water? Remove the hose that goes to the spreader bar and run the unit again, if it moves water as a new pump should check for blockages in that hose and spreader tube. Get back to me if this doesn't work please. Personal email address kidlmo@gmail.com...
Jul 21, 2014 | KitchenAid KUIS18NNT 18" Automatic Ice...
I have a kitchenaid kuic18nnts1 ice maker. It only partially fills the water reservoir causing the pump to run the reservoir dry as the ice is formed on the plate. I have replaced the water level sensor...
Hi hhsawin ,
Have you already check to see any ice blockage in the fill spout tube, this is the hose that caries the water into the freezer section and to the icemaker. If the elbow & tube has a ice blockage, it is usually best to replace the fill valve and the shut off valve. You can try to thaw it using use a turkey baster to spray hot water into the tube.Also there is a solenoid that lets water into the ice cube maker, have a professional check it to make sure its working correctly. Please remember your safety in doing checking and repair.
Hope it helps.
Thank you for using FixYa.
May 10, 2011 | Refrigerators
Have kitchenaid undercounter ice maker, came with the house i bought a year ago. the problem is the water freezes in the resevoir. i have replaced the circulating pump, the thermistor, some sensor,...
on the right side of the ice bin and above the cutter grid are 2 sensor plugs, unplug the one towards the rear of the machine (usually has light brown w/red striped wires). if this does not fix the problem then replace the main control board and the transformer. Also the water doesn't go to the grid, it rolls across the evaporator, freezes a slab of ice that then slides down to the cutter grid. the cutter grid should be somewhat warm, it is what cuts the ice into the little squares. I've worked on these machines for around 7 years now and have only seen this problem once, this should fixya
Mar 02, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
FIM90 spray head
Attach a volt meter to the pump wire terminals and check for voltage fluctuations while in the freeze mode.
Apr 24, 2010 | Franklin Freezer Chef FIM70 Commercial Ice...
Does this ice maker need a pump or is it built in zdis15css
It has a circulation pump that continuosly supplys water over a plate that forms a slab of ice on it. As the slab gets thicker the resistance values change in the ice and the machine opens a hot gas solenoid operated valve which floods the plate with heat from the condenser below. This makes the slab slide down the shoot onto a wire grid that is heated. The slab is cut into tiny little cubes and drops off into the ice bin. So yes the machine has a circulator pump. Ever so often you need to put it into the clean mode and add some nickleguard or ice machine cleaner to keep the pump and its components all happy happy.
Jun 13, 2009 | GE Monogram ZDI15C Automatic Icemaker
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
117 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
