Question about SanDisk Sansa e250 MP3 Player
Sandisk 250 when i turned it on it said that i had bad tracks, then it froze and i couldnt turn it off. then the text got really big. my friends told me to let the battery run out, but now it wont charge. what do i do? please help, i got this as a christmas present from my grammy.
  • 3 Answers
HI I had the same problem I had loaded several songs on my player then took them off yet they still stayed in the list even though when I opened the folder it was empty.they too said bad song, I reloadedall the songs that i took off then i removed them one by one and this solved the problem
Posted on Dec 27, 2007
Got an mp3 station. downloaded updates and player loads, but will not play. help? need to go back to factory settings? how? help!
Ok this is weir this exact same thing happened to me this morning and i was on here looking for help and i came across your post i also went to ten sandisk website and found some helpful info. i just tryed it and my player is fine so what you have to do is take the back off of your player the four screws need to come out then take it off and you will see the battery it looks just like a cell phone battery take it out and put it back in its simple then your player should turn on. let me know if i was helpful my email is applebottem_ME@yahoo.com
Posted on Mar 07, 2007
SOURCE:
E280R was froozen and is still froozen even with it plugged in pc
i'm sorry to hear that. Now, my friend u may go this site for help:
http://kb.sandisk.com/app/answers/list/
Feb 26, 2010 | SanDisk Sansa E280 MP3 Player
Sansa E 250 bad track
On your e250, go to the "Settings" menu, select "USB Mode", and set it to "MSC". Then connect your e250 to your computer. It show up under My Computer as a "removable disk". Right click on it and select "Format". Click on the "Start" button, making sure that Quick Format is NOT checked. Wait for the formatting to complete, unplug your e250, wait for it to reboot (or force it to reboot if necessary), plug it back in, and copy your songs back onto it.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
My w315 wont let me send texts out
That exact thing happened to mine! My w315 doesnt even turn on anymore. You really can't do anything for it sorrry to say. I cant get a new phone til may, so i recommend getting a new phone if you want to text.
Jul 13, 2009 | Motorola Mobility W315 Cellular Phone
Froze when trying to delete track
Did you consider removing and re-installing the battery. THat would turn off the player so that it would unfreeze. I know its crude but its the easiest way out. After you get it working you may want to consider a firmware update from the creative bebsite to ward-off against future problems.
May 10, 2009 | SanDisk Sansa e250 MP3 Player
Cannot get music on or off of MP3 player.
The 260 you can remove the screws on back cover and remove the battery and replace to reset, not sure on the 250, you might also want to go their website and download the latest firmware updates.
May 05, 2009 | SanDisk Sansa e250 MP3 Player
H3y i have a sansa clip mp3 player and i was outside and then it froze and it dont wanna turn on but it is frozin please help me what can i do
Hold in the power button for 15 seconds or longer to reset it. If it freezes again, make note of the track that it froze on, and delete that track (and any others you grabbed from that same source) at your earliest convenience.
-Tha Mp3 Doctor
Jan 10, 2009 | SanDisk Sansa Clip MP3 Player
Sansa 250
okey this sounds ... wierd... you uppgraded it? did it get bad tracks when you putted the tracks in or did it take a time..
your songs maby aren´t in rigth .... are you using mp3\wma songs look so they aren´t any other... well if it don´t helps you you can do 2 things leave it back to store and get help there or try rockbox www.rockbox.org
remember to read alot before installing it
i give you a fast guide about the diffren´t modes you canm boot to :
1.normal only start it while dont push any button
2.recovery mode hold(activated) and push rec button when boot screen comes ( this can be used for reinstalling or uppgrade a mp4)
3.manufrakting mode start mp4 while push centerbutton hold(activated)
4. i think it was one more but i forgot that one :p
Feb 04, 2008 | SanDisk Sansa e250 MP3 Player
Bad Track
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
MUSIC JUST WONT PLAY ANYMORE
Renew Rhapsody subscription and resync
May 19, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
