HEATER WILL NOT LITE
I OPENED MY PROPANE VALVE SLOW, I HELDED MY PILOT SWITCH FOR OVER 30 SECONDS AND IT STILL WON'T LITE. MY
IGNIGHTER IS WORKING FINE CAN YOU HELP ME. I HAVE A RCL30
  • avero Dec 14, 2008
    I have a similar issue but I get beyond that where it ignites on low, but always goes out after about a minute. Also, if I try to turn up to high, it goes out as well. help?! Thanks
    Problem Solver:
  • 7 Answers
Change thermal couple
Posted on Dec 16, 2008
  • pat devera Dec 16, 2008
    you might want to trouble shoot gas valve
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
The pilot light ignights but as soon as I let the knob out to light the heater the pilot goes out. I also noticed that when I depress the pilot knob I can not hear the gas coming out like I use too. I have...
i suggest you change thermocouple on heater it is the pilot control, firstly i would find where it attach's to valve and make sure it is screwed into valve properly (do not over tighten). If the pilot still doesn't go change the thermopile and if that don't work change the valve, but it most likely the thermocouple
Nov 22, 2010 | Coleman (5040B750) Patio Heater
Pool heater
This is an old, but good heater. Power is either stopping thru the safety loop, high limits or pressure switch, or the pilot generator is tiring out and not sending enough power to keep the gas valve open.
May 06, 2010 | Pool & Spa
Pilot will stay on but burners will not ignite, checked all switches seem to be working allright, still no burner ignition
Possibly a flow switch not closed, or a limit switch open. May even be the pilot generator not producing enough mili-volts to operate the gas valve. Safest way is to have it serviced by a heating contractor. You dont have to call a pool company unless you wish.
Aug 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot on main burner won't light.
30 ohms is too high. You generally need it close to or below 1. You need to read the ohms across each switch to find the connection or switch that is holding up your control voltage from opening the valve. If that still doesn't work, jump the th terminals on the valve and see if the valve even opens. You may need a new valve.
Jun 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
