Question about Bose Acoustimass 16 Speaker
Subwoofer blows internal fuse when receiver is turned on
Bose acoustimass 16 subwoofer has been hooked up to 4 different receivers and blows fuse on all,this system is 2 years old but only has approx.40 hours of use and has never been dropped or moved from its current position since bought
    Brigadier General:
  • 8,546 Answers
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
Posted on Apr 28, 2009
How do i hook up bose accustimass speaker to my radio?
Acoustimass speakers need to be driven by a Hi-Fi amp/receiver or AV receiver. So the thing that's driving them needs to be an amplifier.
Unless your radio is also an amplifier then the radio and the Bose speakers are not directly compatible. There's no suitable output on the radio that generates the correct signal in sufficient power.
Sep 07, 2014 | Bose Acoustimass 5 III System
I aquired Bose Acoustimass 15 surround sound through home purchase. Hooked wires up to reciever and hdmi to tv and i got nothing. my question is, how do you turn on the sub? just plug it in?
Hey Any chance you have the Acoustimass 15 II or III? The first Acoustimass 15 has a switch. The II and II models turn off and on when it receives a signal from the source you are using. Amplifier, ect. All you need to do is make sure everything hooked up correctly and plug it in.
Aug 02, 2014 | Bose Acoustimass 15 System
Bose acoustimass series 5 subwoofer doesn't work
I guess it is powered.If so,check the fuse,then transformer.If these are Ok,then there's probably a fault in the power circuit.
Sep 29, 2012 | Bose Stereo Subwoofer Speaker Acoustimass...
Hi, I bought a Bose acoustimass 16 - 6.1 channel, iam curious to know which receiver is suitable for that.
I would get a receiver that puts out a little less power than the speakers can handle. This will prevent you from blowing them by sending too much power to them, but will still send enough power to make them sound good.
An example would be, if you're speakers have a combined power of 500 watts get a receiver around 495 watts or a little less.
May 03, 2011 | Bose Acoustimass 16 System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Initial Bose Speakr Hook-Up Acoust 10-Denon RCVR
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
http://www.allbose.com/Question.aspx?id=64108
(Page11)
http://www.riverparkinc.com/techpdf/Bose%20AM6%20&%20AM10%20Series%20III%20owners%20manual.pdf
Dec 14, 2008 | Bose Acoustimass 10 II System
Subwoofer blows the internal fuse when receiver is turned on
possible solution - this can be caused by a fault in the receiver unit. the sub has a triac 'high side switch' circuit that can cause the fuse to blow if it doesn't get a good switching signal e.g. if the receiver power supply is not running at the full voltage. check the plug pack wire for damage, check the 12v input area on the receiver board for dry joints, particularly the power input socket. hope this helps.-pj
Dec 11, 2008 | Bose Acoustimass 16 Speaker
Receiver for Bose AM-16 6.1 speaker
i added the vcs 10 center channel speaker for 180 to "upgrade" to the 7.1 and bought a new pioneer vsx-91txh receiver on ebay for 515.
Feb 14, 2008 | Bose Acoustimass 16 System
Bose Acoustimass  16 Speaker Logo
585 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
