Question about Roper RAS6233KQ Top Load Washer
My washing machine wont spin
My roper washing machine wont spin I have the same problem, it drains but won't spin.
    Top Expert:
  • Roper Master
  • 77,514 Answers
Have u checked he drive belt?
Posted on Dec 12, 2008
  • yadayada
    yadayada Dec 12, 2008
    When this happened to me, I turned my empty washer over and found a broken belt lying on the floor. I called the local supplier for
    such and reinstalled it myself. It's been about 10 years, so I don't remember if it was TOO hard, but
    I believe it was NOT too hard with proper tools, otherwise I would have called repair because I had money then. God bless you for being willing to ask
    around and to try to DIY first to be more FRUGAL.
Roper washing machine fills and washes, but when it gets to the spin cycle there is no sound and it won,t spin.
Hi m3gamma1,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Washing Machines
My roper RAX4232KQO washers but won't drain. What could be causing this?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2011 | Roper RAX4232KQ Top Load Washer
My Roper washing machine will not drain the water after the wash cycle.
heatman101
Apr 17, 2011 | Roper Washing Machines
Wash machine wont drain or spin
heatman101
Oct 13, 2010 | Roper RAX4233PQ Top Load Washer
Spin cycle wont work
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 23, 2010 | Roper RAS8445KQ Top Load Washer
My washer spins but will not drain. the pump seems to be working but wont drain
The drain line is probably clogged... sometimes debris or small objects can get in between the tubs and plug the lines...if not, the pump may be bad. I just replaced my pump on my GE washing machine.
May 19, 2009 | Roper RAX4233PQ Top Load Washer
I have a Roper washing machine Model RA58445KQ that will was but wont spin or drain
If you hear a loud noise when you put it into spin then the motor coupler is broken. Very common problem.
Nov 26, 2008 | Roper RAS8445KQ Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
How do you open the top to replace the lid switch?
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
76 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
